587,923 active members*
3,472 visitors online*
Results 1 to 11 of 11
    Feb 2012
    387
    G.WEIKE LASER MACHINE NEW DESIGN
    LG6040B laser engraver
    This modle adopts three-phase motor and driver ;high-speed outside Rail ; high speed USB 2.0 data interface support ,32M high speed DSP controller .Applied in clothing ,fabric ,leather and other Soft materials .
    Specification:
    Laser- type:CO2laser beam
    Laser power:60W
    Engraving area:600X400mm
    Engraving speed:0 - 1000mm/min
    Cutting speed:0 - 800mm/min
    Resetting position accuracy:± 0.05mm
    Controlling system:DSP
    Cutting thickness:0-30mm(According to imaterials)
    Cooling mode:water-cooling and protection system
    Gross power:≤1250W
    Working voltage:220 ± 10%,50HZ(60HZ)
    Operating temperature:0℃-45℃
    Operating humidity:5%-95%
    Controlling software:DSP
    Graphic format supported:BMP,PLT, DST, DXF and AI
    Net Weight:200KG
    Attached Thumbnails Attached Thumbnails LG6040B laser engraver副本.jpg   LG6040B.jpg   428150846_444.jpg   control panel&DSP system.jpg
    Feb 2012
    387
    newest model for laser machine
    Feb 2012
    387
    anyone or anybody want to have their own design,we also can make as customer's demands
    Feb 2012
    387
    more new models will come soon,then we will show details later
    Feb 2012
    387
    new model is coming
    LC1390S laser cutting machine
    1390S is our latest high-precision laser cutting equipment. Mechanical systems using high-precision Ball Screw Driver Mechanism, X, Y direction of transmission using split design, which are an excellent solution for the reduction of cutting precision of the traditional laser cutting machine caused by the interference cutting trajectory. Cutting path becomes smoother. Excellent electrical system design, system stability and high interference. With advanced Real-time embedded DSP laser cutting control system, run faster, and speed automatically matches the laser intensity, the effect of cutting corners to achieve the perfect consistency. Imported high-precision optical system optical components, a substantial increase in the efficiency of light reflection and focusing effect, greatly improving the efficiency of laser energy control, work piece quality and class.
    Features:
    (1) Control system: high-speed DSP real-time motion control system that supports computer-to-output and U disk and other files directly read mode;
    (2) Adopt the U.S. Ⅱ - Ⅵ high-performance optical Reflecting Mirrors, Focusing Lens;
    (3) TBI Taiwanese high-precision Ball Screw Driver, which ensure the accuracy of the system working;
    (4) Imported high-performance servo motor;Y double-screw drive shaft, cutting trajectory smooth.
    Specification:
    Laser power : 150w
    积Cutting area :1,300X900mm
    position accuracy:+/-0.05mm
    cutting thickness :30mm (max)
    cutting speed :20m/min (max)
    Whole machine size:
    machine weight:500kg
    power demand:220V+/-10%/40A
    Applicable materials:
    Rubber, plastic, organic, glass, leather, , ceramic, crystal, jade bamboo, wood, paper ,acrylic ,electronics and other nonmetal materials.
    Applicable industries:
    Packaging, leather printing , advertisement decorating building upholster , arts and crafts, , model , ,electronics and other industry .
    Quote Originally Posted by gweikelaser View Post
    Attached Thumbnails Attached Thumbnails 58253049.jpg   LC1390S laser cutting machine.jpg
    Great stuff
    II-VI mirrors and lens systems are likely the best in the world.
    best wishes
    Dave
    Feb 2012
    387
    yes,this model with the high configuration ,is one of our newest machine
    Feb 2012
    387
    LC1625 laser cutting machine
    Product features:The machine is especially designed for garment industry, it can do accurate cutting on different kinds of on various textile fabrics in random figure. Adopt in size crawler working table and negative pressure absorb conveyer, so it can ensure the smooth of the material when cutting. . Working in with feeding system,it can meet the requirement for continuous and automatic batch cutting.
    Aplicable range:This model is suitable for different kinds of textile, especially Seamless bonding fabric;
    Designed for garment industry.
    Specification:
    Laser Power: 80W output power
    Working area: 1600mm×2500mm
    Cutting speed: 0-36000mm/m
    Work platform: rawler type work platform
    Working speed: Adjustable
    position accuracy: ±0.1mm
    Control system: DSP DSP control system in USB mode
    Cooling mode: constant temperature water-cooling
    Working voltage: AC220V±5% / 50HZ
    Graphic format supported: AI、BMP、PLT、DXF、DST等
    Operating temperature:0°C-40°C
    Operating humidity:5-95%
    Gross power:<2000W
    Whole machine size:
    Weight:
    Wood , paper, leather, garments, organic glass,epoxy resin, acrylic, wool, plastic,ceramic, crystal, jade, bamboo and other nonmetal materials。
    Applicable industry:
    Garment, leather, Plush toys,Computer embroidery。
    Feb 2012
    387
    G.WEIKE NEW CNC MODEL
    GWEIKE NEW MODEL FOR CNC ROUTER
    which with two working area ,one is level and the other is vertical,suible fore
    any special demands,more photoes for refrence
    Best Regards
    Lucy Lee
    G.WEIKE LASER
    [email protected]
    Attached Thumbnails Attached Thumbnails IMG_6107.JPG   IMG_6108.JPG   IMG_6111.jpg   IMG_6112.JPG
    Oct 2009
    24
    HI i am looking for a laser cutter that can cut and engrave 2 - 3 mm plexiglass and cut 2mm aluminium.
    I do not have a lot of space so i was hoping on a 60 by 40 cm working area.
    What do you suggest?
    Feb 2012
    387
    LG6040
    Hi stekke_stim,
    we have a model LG6040,with 60w laser power,80w,100w or 130 ,150w even more for option,its specification will be enclosed for your refrence
    However ,our laser machine only can engrave or cut nonmetal materials,for pleaxiglass,it is ok,but aluminum,feel sory for this .if cutting metal,we have YAG 500w machine ,but price is much higher.
    Whether it fits your demands? price will send to you by private messages ,or more details such as working videos if need,would you please let usk now your mail address or write to me :[email protected]
    Best Regards
    Lucy Lee
    G.WEIKE LASER
    [email protected]
    Quote Originally Posted by stekke_stim View Post
    Attached Files Attached Files
  1. G.weike laser engraving machine technique service
    By cicigweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-29-2012, 07:15 PM
  2. G.Weike Laser - Top Three Sales Model in 2011
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-21-2012, 01:06 PM
  3. G.Weike Laser
    Last Post: 09-28-2011, 09:20 AM
  4. New Machine Design book from Alexander Slocum (of Precision Machine Design)
    By toastydeath in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2009, 05:37 PM
  5. Shaft dia requirement, for a new laser machine design?
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-20-2004, 12:53 AM
