Re: New control panel build looking for advice on the layout.
Originally Posted by
bgolash
. Anything with inductance; coils, motor, electro-magnets etc, can cause
high voltage spikes when turned off. If your motor drivers are of a switched type, they may be the cause.
Second, the probes usually have setting slike 1x, 10x, x100 with 10X is the most common. The X is actually a divider,
ie a 10x probe divides the signal by ten, and if you set the scope input to X10 it will multiply the result by ten to get the
right reading. When working with inductors, coils, set the probe to 10x or better 100x until you have seen what the signal
looks like. That will give some protection to your scope from high peaks.
PS You can see an inductor and causing an inertia for electricity. Trough ann inductor, Current is "hard to start, hard to
stop", has inertia. A traditional car ignition coil is simply a magnetic coil that you run current through. When you cut the
current, it has "nowhere to go" but converts into a high voltage spike. In cars, this converts 12V to short ignition spike of several thousand volts.
Most drives whether stepper or servo are PWM based, these produce a square wave of varying width (energy) the resultant current through the motor does not follow the voltage waveform but has a mean level saw tooth in shape.
The voltage in a ignition coil is due to the rapid collapse of the stored induced energy, this also happens when you turn a relay off, as you may have noticed, there is a BEMF diode often placed across the coil to provide a very low impedance path to this collapsing field.
PWM drives also have these types of devices across the switching Mosfets or IGBT's to suppress reverse spikes.
The x10 x100 probe switch is so that very high voltages can be measured that otherwise could not be displayed on the scope directly.
Drives of all types generally have internal power supply capacitors, as well as those provided in the power supply itself.
Al.
