Ahh, got it. What's chassis, though? Also, do I need specific resistors or any 2.8k and 3.5k resistors will do?
Does the polarity of the connections going to the steppers matter as long as they're wired to the correct coil? I've seen multiple diagram's, even from the same source that seem to contradict. Here are some examples. That Gecko manual does not identify polarity on the pins, just which are A or B wires.
Polarity does matter hence the pairs of wires being marked A+, A-, B+, B- etc.
Regards
Geoff
Exactly. The first 2 docs I attached were both from Keling and show
A+ 9
A- 8
B+ 7
B- 6
However if you look at post #4, their own doc shows another motor model wired reversed. The 3rd doc I attached from Homann shows them reverse as well from the first 2. I'm not feeling totally confident here and the manual from Gecko directly doesn't say + or - just A and B.
I think Homann's got it backwards. /A and /B are the same as A- and B-
Bob
"Bad decisions make good stories."
