587,308 active members*
3,768 visitors online*
Page 2 of 88 12341252
Results 21 to 40 of 1750
  1. #21
    Aug 2004
    3215
    Well I got tiered of using a wrench and nut to clamp down my parts so I made a few of these, Knobs like that with 1/4" thread inside are almost $3.00 at the hardware store (must be proud of them or something) so i made a few of my own.
    Here is a picture of some and also the g-code if people want to make their own, (.25 end mill 3/4" stock) Rename the *.Zip ext. to *.Tap can not upload the file otherwise.
    Attached Files Attached Files
  2. #22
    Aug 2004
    3215
    Got the Z Axis Carriage done, I think i pushed my HP motors to their limit, I cut these at 40ipm with no problem.
  3. #23
    Aug 2004
    3215
    Z Axis Carriage assembled, will have 4 - 1/4" threaded rod through sides, top and bottom to make sure the pressure of the bearings on rails do not start to push assembly apart.
  4. #24
    Aug 2004
    3215
    I got my 1/2"-10 acme threaded rods, and my 36" drill rods (i cut them to the proper lenght)
    I desided to use the same type of Anti-backlash nuts I made for the 5/16" rod and nuts.. so here is its big brother....
  5. #25
    Aug 2004
    3215
    recieved my LoveJoy couplers today to go from the 1/4" Motor shafts to the 1/2"-10 Leadscrews, These things are tough to put together...
  6. #26
    Aug 2004
    3215
    Here is a look at the gantry so far...
  7. #27
    253
    Joe, are you bolting the sides onto the torsion boxes? Or using threaded rod? I ran 6 pieces of 1/4-20 threaded rod through the whole thing and I'm pretty sure it's responsible for a lot of the gantry strength. You can buy big 10ft pieces at Home Depot for less than $3 a piece. At my local HD it was near the electrical conduit.
    Andy
    CNC Kits - http://www.comptonsoft.com/cncweb/
  8. #28
    Aug 2004
    3215
    Quote Originally Posted by Lionclaw
    Yes i will be using 4 all the way through it i bolted it for now and as soon as i get ready to put it all together i will get the rods and cut them to the right lenth, the bolt place i get everything from they are 2.50 for 10ft. I agree it will increast the strenth, and i will place them as well on the X axis slide carriage.
  9. #29
    Are the skins on that gantry torsion box screwed on, or glued? It looks like they're screwed on, but I believe gluing them makes the box much more rigid.
  10. #30
    Aug 2004
    3215
    Quote Originally Posted by ger21
    Everything is glued even the rib sections then drill and tapped, the bolts may help a little but does give it that industrial look... lol
  11. #31
    Oct 2005
    42
    Looks great Joe!
  12. #32
    Aug 2004
    3215
    Here are the Z Axis Slide Bearings I made.
  13. #33
    Quote Originally Posted by joe2000che
    I had already recieved my 1/2" inside dia. bearings for the acme 1/2-10 leadscrews i ordered. (you could use 1/2"-13 standard thread also but I want to maximize speed), So i drew up a Leadscrew Bearing Support which has same bolt pattern as the Nema 23 motors.
    Joe,
    I'd like to get some of these 1/2 inch inner diameter bearings. Do you still have the part numbers?
  14. #34
    253
    I got mine from someone on ebay named "gem_supply".
    Here's a link:
    http://cgi.ebay.com/10-1616-ZZ-Shiel...QQcmdZViewItem
    $16 shipped for 10 bearings, you can't go wrong.
    Andy
  15. #35
    Aug 2004
    3215
    Quote Originally Posted by mvaughn
    Joe,
    got mine from VXB.com
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7556622868
    Joe
  16. #36
    Thanks gentlemen!
  17. #37
    253
    Joe, where did you order those from? I've never seen any where the spider sticks out past the coupler. Those spiders might have been made for a larger coupler.
    Andy
  18. #38
    Nov 2005
    938
    Hi Joe,
    Do you (or anyone else following this thread) have any experience with using oil impregnated bronze bearings as slider bearings? I see you made yours out of what looks like HDPE, I have seen some people make them out of wood (which doesn't seem like it will make a very good bearing to me). McMAster-Carr sells the oil impregnated bronze for about $5 each (though they have some going as high as $30 if you want them to have grease grooves cut in them.
  19. #39
    Aug 2004
    3215
    Quote Originally Posted by sdantonio
    Hi Joe,
    I have never used any, mine are tight enought but slide with a little sillicone spray.
  20. #40
    Aug 2004
    3215
    The X-Axis Carriage finished and painted.
    You have to make sure the bearings are installed before assembling and glued together, I painted the pieces seperately the areas that would be on the inside, making sure not to paint the cut groves and outside edges of pieces so the glue would adhere to the wood for a tight bond. then used news paper to mask off the bearings aqnd then painted the outside.
  1. Two more of Joe's CNC Model 2006
    By JLT in forum Joes CNC Model 2006
    Last Post: 01-31-2019, 02:27 AM
  2. [AU] Joe's 2006 Model
    By nat.andrews in forum Joes CNC Model 2006
    Last Post: 11-11-2013, 11:50 AM
  3. Electronics for a Model 2006
    By joegtp in forum Joes CNC Model 2006
    Last Post: 08-31-2011, 04:43 PM
  4. New to Joe model 2006
    By Darroll in forum Joes CNC Model 2006
    Last Post: 01-16-2008, 11:31 PM
  5. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
