Originally Posted by
JRoque
Hi. Wow, that was some write up.
My 2.4kW Porter Cable router is a behemoth compared to those motors you mention. It spins at 21K RPM max and at full speed/power it gets bogged down if I dive it in too hard. They all do. And if that Porter Cable gets loaded like that, the motors you mention above will too.
The key ingredient missing from those hobby motors is torque. I seriously doubt they get much useful torque out of that 6.5kW input. Also, it's not easy to get 6.5kW out of a standard outlet. You'll need 220V @ 30A for that. You will also need a spindle with bearings that can take the cutting loads.
If you want to cut oak, your best bet is a wood router like the Porter Cable. It's got lots of torque, an integrated fan and the bearings to do the work. It will be loud and your oak chips will fly everywhere but it'll do it.
JR
