Hey,
Runout seems very good but I havent tested with a dial indicator yet. I plan on checking it after I mount it on the router. A lathe is a must for this kind a project. Every piece was machined on my crappy Harbor Frieght 7x10 lathe. Cutting stainless really SUCKS!!! I killed a bunch of carbid bits. Its also really hard keeping the run out 0 when using the lathe. A steady rest is also very important.
I do use mach3 (just the demo for now) and havent really thought about trying to controll the rpm. I do want at least controll spindle on or off though and to be honest I havent even gone down that road yet. I forsee problems with a rc brushless conroller though. In order to controll a brushless esc you need to use a servo tester. Its a device that emulates the pulses created by a rc reciever. Im sure it could be done but it would uncharted territory. For now just using a relay to controll the power supply will be good for me.
Saddly I always intend to document my builds but I always get cought up in the build. Then its to late if you havent taken pics the entire time.
Like I said before, none of this is an original idea. There are a few threads I have pointed out before that have every bit of info I used to build mine.
Look for any post from herbertkabi, that dude has really figured out the hard stuff.
Read this entire thread!!!
http://www.cnczone.com/forums/showth...p=94477&page=5
That thread is chocked full of good info. Also read as much as you can about Angular contact bearings. Before I started down this road I really had no idea how complicated mounting bearings can be.
Have fun, I will add more pics after I get this running a 100%
