587,700 active members*
3,443 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > New!2200W 3000~10000RPM BLDC Motor Controller
Page 4 of 13 23456
Results 61 to 80 of 241
  1. #61
    Apr 2007
    157
    Ramp Up Speeds
    Does anyone know the Ramp up speeds in CNC Mode? I have a Syil SX3...I run it in "Manual Mode" because of the time it takes to get to say 2850 rpm....or any given RPM in CNC Mode. will this control be able to get to say 3000 RPM by the time my program is starting a cut? My rapids are 100 ipm.
    Thanks in advance.
  2. #62
    Quote Originally Posted by Journey_Man View Post
    Thanks in advance.
    hi Journey_Man
    could you give us more detailed description about the comfuesd you have meet ,or you hope we how to help you to solve the problem.
    Do you means the motor in "manual Mode"can not get to 3000rpm???
    If anyone can explain to journey,please tell him and us .Thanks
    zhang
    web www.sangmutan.com
    E-mail [email protected]
  3. #63
    Jan 2010
    35
    Quote Originally Posted by JoeBean View Post
    FYI to those interested:
    Novakon has started using these motors/controllers in their mills, at least with the NM200 series 2 (2.2kW version). Seem to work fairly well.
    I heard Novakon has many complaints in this zone, lack of support.
  4. #64
    Aug 2004
    203
    Lightbulb
    Thanks in advance.
    I'm assuming you have the older version? It apparently had an odd "bug"/"feature", depending on who you talk to. You need to manually input in your g-code a dwell to allow time to ramp up. Some have used a saved procedure/routine to do it in steps, which is apparently faster for some odd reason. See http://www.machsupport.com/forum/index.php?topic=8289.0.
    Also, note that mach3 or EMC may be set for dwell to be expressed in seconds, not milliseconds, so g04 s1000 would have you paused for 16+ minutes. So check your settings and adjust accordingly...
  5. #65
    Aug 2004
    203
    Quote Originally Posted by hobby1818 View Post
    Not from everyone. I'm happy with them. But the forum has been overrun by useless bickering and I don't post there, or usually on cnczone, now.
    That said the chap that quoted my first comment in this thread on the las t page was a bit odd. I don't know his purpose. Mine was simply to help Novakon users ID the new spindle maker to get an idea of what they're getting, and to help potential customers for this spindle get another source of feedback on it's performance.
    I'll go back to silent running now...
  6. #66
    Feb 2009
    137
    Drive adjustments
    Zhang,
    I would like to know more detailed technical information about the drive and features.
    What is the method to connect to the drive on the RS485 port?
    What is the communication protocol used? Modbus?
    Can drive parameters like accel, decel, and PID tunning be adjusted?
    Matt
  7. #67
    Quote Originally Posted by mmprestine View Post
    Zhang,
    Matt
    HI Matt
    please send E-mail to me ,my E-mail address " [email protected] "
    i will send the motor and controller specification to you ,our motor and controller is use in CNC milling and drilling machine match with MACH3.
    Or you can contact kelinginc,i have sent dozens of motor an controller to Chicago,you can buy from him,his e-mail "[email protected]"
    1100w 6000rpm motor and controller
    2200W 6000rpm motor and controller
    Best regards
    zhang
    www.sangmutan.com
    [email protected]
  8. #68
    Quote Originally Posted by japroach View Post
    I have the 1100W motor + controller running currently on the bench, working ok.
    PCB is very well designed. Output module is highly rated at 20A 600V. dsPIC is used for main controller. Another PIC is on the LCD for manual speed control (over rs232), or PWM/0-10V inputs are available for mach3 control. Speed control seems alright, but I can't really say until I've tried actual cutting loads. Also haven't figured out the tapping mode.
    Motor looks decent, uses dual 6203 bearings. Although windings didn't have a varnish dip, not sure how important that is.
    Would be nice if this type of item were easier to purchase, value is excellent. Keling is not bad, but I've gotten quotes for their brushless stuff and its about the same cost to buy sample quantity direct. Guess the volume just isn't there.
    Hi All
    We have the 1100W,2200W, 6000RPM Spindle + Driver in Chicago office now
    Pls check here if you need them
    http://www.kelinginc.net/CNCmillingcontroller.html
  9. #69
    Oct 2010
    Quote Originally Posted by Kung fu panda View Post
    HI Matt
    Best regards
    zhang
    ShenZhen Sangmutan Motor Co.,LTD|BLDC Pump|BLDC Motor|Brushless DC Motor|Brushless Motor controller|Brushless DC Pump|Pump|WaterPUMP|???--????? |?|??|?||||?||?||pwm|???|??| - index
    [email protected]
    __________________
    watch movies online
  10. #70
    Apr 2007
    157
    Quote Originally Posted by leencoo12 View Post
    I would like to see these Questions Answered in this post so we All would have the Same Documented Answer....
  11. #71
    @ for 1.1KW just need to connection the cables to CN10,if controller with this functional.
    @ for 2.2KW just need to connection the cables to CN1,if controller with this functional.
    (We just retain the function, but it didn't do to the board, unless the client has special needs , then he need to provide application environment.... we need to confirm a lot of things, not one or two sentences can be clear)
    Now the driver is nice to match with MACH3,customer can use it Automatically or manually
    This protocol is not for official,
    @ Can upgrade Controller software to have this functional if needed .
    [email protected]
    zhang
  12. #72
    Apr 2007
    157
    Thank You Zhang! I believe that you have Proven the Integrity of your Product and the Willingness to Share the Specifications...Openly... for All to see!....It keeps Honest People Honest....Again Thank You!
  13. #73
    Hi everyone ,
    New order will send to Chicago, 2200W 6000rpm ,1100W 6000rpm ,can buy from kelinginc.In Chicago.
    [email protected]
    http://www.sangmutan.com
    zhang
  14. #74
    [quote=Kung fu panda;843911]Hi everyone ,
    Brushless motor use in PUMP , instead of Ordinary Ac motor ,
    BLDC motor ----Energy saving, high efficiency,what do you think of it ?
    [email protected]
    Attached Thumbnails Attached Thumbnails 2200W 6000Rpm.jpg   BrushlessPUMP.jpg   PUMP.jpg   PUMPour motor.jpg
    Attached Files Attached Files
  15. #75
    Oct 2008
    1641
    I haven't seen any updates on this thread and I've heard that the factory is working on a way to tune the PID loop for better response. Personally I'm awaiting some positive results on the motor response before I convert my machines.
    Does the factory have an update on this KungFu Panda?
  16. #76
    May 2007
    715
    I have contacted John at keling and he sent a message and CCed me to Zhang about the resolution timeframe. Awaiting the response.
  17. #77
    Quote Originally Posted by rwskinner View Post
    Hi everyone
    Our engineers are modifying software programs,you know sometime the software need to Constant adjustment, then do experimental detection,Please give us some time ,when it is ok ,i will tell you,and sent the MCU PCB to kelinginc.
    Best regards
    zhang
  18. #78
    Quote Originally Posted by cjdavis618 View Post
    Yes , i have receive your mail ,when our engineer improve the software ,i will send the MCU to kelinginc for everyone to change.Give me some time ,i will give you a good answer. Thanks
    Best Regards
    zhang
  19. #79
    Dec 2010
    116
    It's great to see this problem is being addressed. I'm impressed by the product back-up and support! I'll be ordering one just as soon as the problem is rectified.
  20. #80
    Jan 2011
    63
    It has been over a month since this thread was last updated... what is the status of the revised controller board to correct the problems discussed in this thread?
    Charlie.
    Hi everyone
    Best regards
    zhang
    Visit http://www.shadowspawnllc.com to see what enhancements I have available for the NM-145.
Page 4 of 13 23456
  1. Bldc motor and controller is used in the mini machine
    By wang in forum News Announcements
    Last Post: 09-14-2014, 08:58 PM
  2. Open Source 3 Phase BLDC controller
    By karl1 in forum Open Source Controller Boards
    Last Post: 02-10-2009, 11:35 PM
  3. Regarding Transferfunction of BLDC Motor
    By pathamuthu in forum CNC Machine Related Electronics
    Last Post: 01-27-2009, 09:30 PM
  4. Electrocraft BLDC motor, need some spec's.
    By lucas in forum Servo Motors / Drives
    Last Post: 02-17-2008, 07:53 PM
  5. Help inspecting/repairing a BLDC motor.
    By ESjaavik in forum Servo Motors / Drives
    Last Post: 08-16-2004, 11:32 PM
