587,475 active members*
3,655 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Anybody have a working PCI parallel card for G540 w/ charge pump enabled?
Page 1 of 2 12
Results 1 to 20 of 30
    Jan 2009
    28
    Trying to find an add-on card that works with the G540 charge pump circuit. When the pump is disabled everything else seems to be fine, I can jog the motors and there appears to be no other issues, but no matter what I can't get the Charge Pump to enable without faulting. At this point I can only assume it's the PCI parallel card.
    Pertinent info:
    - G540 in pre-wired Keling box
    - Mach3
    - DB25 straight thru cable
    - EPP compatible PCI card with latest mfg driver file (Rosewill RC-304)(Most likely not 100% EPP according to the FAQ's on the Rosewill site)
    - Port address is correct in Mach3
    - 540B xml file from Gecko (Charge Pump on port #1, pin 16)
    - "Use Watchdogs" and "Charge Pump on in e-stop" are both checked in the General Configuration table.
    - I don't have an option for EPP in the Device Manager anywhere.
    - Win XP
    So, does anyone out there have a PCI add-on parallel card that can get the charge pump to work with a G540 and Mach3? If so, what card and was EPP an option in Device Manager or maybe a seperate utility?
    Any help or advise appreciated.
    Regards,
    Frank
    Feb 2007
    4553
    Post
    Frank,
    Siig works when all others fail.
    http://www.siig.com/ViewProduct.aspx?pn=JJ-P00112-S6
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2009
    28
    Jeff,
    Did it work right out of the box or did you have to select EPP mode somewhere?
    Feb 2007
    4553
    Post
    Frank,
    We have used Siig on several customers machines, I don't recall the device manager configuration.
    The Moschip NM9715 "Rosewill RC-304" has been discontinued for almost three years due to compatibility issues.
    Moschip replaced the NM9715 with the NM9815 "9800 series" .
    Sorry I could not give more detailed info on the Siig.
    Jeff...
    Feb 2008
    243
    You don't set EPP in device manager you set it in bios.
    Dan Mauch
    Quote Originally Posted by Jr's Farm View Post
    Pertinent info:
    - Mach3
    - 540B xml file from Gecko (pump on port #1, pin 16. Watchdogs yes and pump on e-stop)
    - Win XP
    Regards,
    Frank
    Jan 2009
    28
    Quote Originally Posted by dmauch View Post
    Dan Mauch
    I think you might have missed the fact about the PCI parallel add on card. The BIOS only works for the motherboard integrated parallel circuit, which I unfortunately don't have.
    So I'm looking for a way to utilize EPP on a PCI add on card. As I undertand it, on compatible cards it may be an option in Device Manager.
    Frank
    Aug 2005
    1101
    Homann Designs - http://www.homanndesigns.com/store
    Jan 2009
    28
    Quote Originally Posted by phomann View Post
    Thanks for that, but I've already tried that. I tried to mention that in my original post but I guess I may have been vague. My apologies.
    I edited and reworded the original post to help eliminate confusion.
    Regards,
    Frank
    Oct 2009
    105
    Frank,
    You and I definitely are having the same problem. See my post on green light... as I have added more info. I just ordered a Lava PCI card. We'll see if that one works. It uses a different chip, so maybe I'll get lucky this time. I'll keep you informed.
    Ron
    Jan 2009
    28
    ronncat,
    Quoting you from your "Need Help! G540 Green Light..Go or no go? " thread here, as the info form Mariss might help others understand the shortcomings of the PCI parallel card issue. Great info!
    Quote Originally Posted by ronncat View Post
    Looks like Jr and I have a similar problem. I currently have a Startech PCI parallel card installed in my XP computer. The driver test gives excellent results... However, the charge pump does not work.
    THIS IS WHERE I GIVE MY SINCEREST THANKS TO MARRIS AT GECKO!!!
    I called tech support at Gecko with several questions and concerns about my G540. Eventually I was treated to an extended conversation with Marris. He broke down all of my questions and answered them in a way that a non-electronics whiz could understand. Marris also gave me an incredible amount of other info that I will definitely be able to use during my install.
    In short, this is what I learned...If the parallel port is not set to EPP or ECP, the drive motors will still work, but the other features of the G540 will not work with any consistency. VFD, and outputs 1 and 2 will not be functional, nor will the charge pump. These "extras" of the G540 may work from time to time, but without the extra boost in output that EPP affords to the parallel port the voltage may be too close to the cutoff for active high or low.
    Marris also instructed me to wire a 1 amp diode (1N4004) with the cathode side connected to the + DC side of the power supply in parallel to the solenoids I was using to control spindle and coolant for outputs 1 & 2. This was so when the coil deenergizes, you won't blow up the power supply.
    I contacted Startech re: setting the PCI parallel port to EPP. They were unable to help and suggested I contact the chipmaker MosChip to see if there was anyway to modify the drivers. So......Anyone know how to switch a MosChip NM9805 to EPP. This is a PCI port and does not show in the Bios. Also no options in device manager to do so. (At least that I could surmise)
    Guess my next step is to call MosCip...
    And of course your followup with the Moschip info pretty much states the same that I found at Rosewill (use's Moschip 9815), in that you can only change the port mode in DOS or Windows NT. I'm not sure how they can say that the card is compatible with all the software they say, when clearly it's not.
    Oh well. Still looking.
    Frank
    May 2009
    7
    Did this get solved?
    Hi-
    I'm having the same problem. My onboard parallel port doesn't support EPP in bios and I've tried MosChip and SIIG cards. Did anyone find a card that works? Has anyone tried to solve this with the CNC4PC C26 - Output Buffer Board?
    Thanks,
    Kevin
    Apr 2004
    135
    G540 and MOSCHIP based parallel ports
    The problem with MOSCHIP (and possibly other) interfaces driving the G540 signals other than step and direction results from the outputs being "open drain" unless the interface is set to EPP mode which cause the chip to use regular totem-pole TTL style output drive.
    The G540 inputs are just a current limiting resistor feeding the positive side of an LED inside of an optocoupler. The negative side of the LED is returned to ground. This means that the parallel port signal must be able to source enough current to turn on the LED. The open drain style outputs cannot source current and rely on whatever pull-up resistor the board manufacturer provides as the source of current when the signal is supposed to be high. This resistor is often a large enough resistance value to limit the current to a value below the response current threshold of the optocoupler.
    When the port is set to EPP mode, the chip actively drives the signal high and the problem goes away.
    I do not know if any parallel port chips will behave differently, so the solution is to find a board that provides you with a way to set EPP mode without assistance from the BIOS. This will probably take the form of a utility or driver supplied with the board.
    Some breakout boards, including PMDX products, will buffer the signal with a CMOS gate instead of directly driving an optocoupler. This reduces the probability of the problem but may not always eliminate it. Some PMDX boards have a 10K ohm pull DOWN resistor to assure that an input that is not connected assumes the LOW state. If the pull up resistor on the open drain outputs of the parallel port are greater than 5K ohms, operation may not be reliable. The original IBM parallel ports used 1K ohms and most but not all vendors followed this tradition.
    Regards,
    Steve Stallings
    www.PMDX.com
    Feb 2008
    243
    CNC4PC has PCI parallel port card that does support epp http://www.cnc4pc.com/Store/osc/prod...roducts_id=250
    [email protected]
    low cost G540's at adisount over retail, cases kits and assembled units.
    Quote Originally Posted by kdaniel32 View Post
    Hi-
    Thanks,
    Kevin
    Jun 2005
    138
    Here's a suggestion for a device that I own and use with tremendous success, but I am NOT the seller. I paid retail for my first one and just bought a second one from someone who needed the money.
    Buy a SmoothStepper and start running from your USB bus, and give up on using the parallel port at all. I'll even give you the link - http://www.warp9td.com/
    May 2009
    7
    But does it work with the G540?
    Thanks for the link. The cards I've already tried had EPP support but only if they detected an EPP compatible device via some handshaking. Do you know of anyone running the G540 with the CNC4PC card?
    [email protected]
    May 2009
    7
    The CNC4PC C26 Output Buffer Board might work
    The CNC4PC C26 Output Buffer Board fixed my issue with the charge pump not working with onboard parallel port. I'll post again after I test the VFD and relay outputs.
    May 2009
    7
    CNC4PC C26 fixed all of my G540 issues
    The CNC4PC C26 Output Buffer Board / G540 combination is working for all functions: VFD, charge pump, inputs, outputs.
    Feb 2008
    243
    I don't see how the C26 could have fixed the EPP issue. The reason is that EPP changes the state of the tri state output of the parallel port. The c26 is just a buffer that increases the current for the various input pins. So that low parallel port voltage or current can be corrected. It does not provide the charge pump signal.
    Dmauch
    Camtronics, inc. -- CNC with Dan Mauch
    low cost cases for the G540, steppers and servo systems.
    Kits, custom and assembled units.
    Apr 2004
    135
    The C26 board has inputs that are high impedance so it accepts the "open drain with pull-up resistor" generated signal without problems. It has buffers that have "totem-pole" outputs that can source the current needed by the optocouplers on the G540 inputs in the same fashion as a parallel port that has been set to EPP mode.
    Regards,
    Steve Stallings
    PMDX.COM - Products for CNC and motion control applications
    [QUOTE=dmauch;831991]I don't see how the C26 could have fixed the EPP issue. The reason is that EPP changes the state of the tri state output of the parallel port. The c26 is just a buffer that increases the current for the various input pins. So that low parallel port voltage or current can be corrected. It does not provide the charge pump signal.
    Dmauch
    Aug 2008
    110
    Talking
    Hi morestuff
    How are you getting on with the C26 board from cnc4pc.
    I fell into the trap with the Gecko G540 and the PCI parallel port.
    I have the Sunix twin parallel card, works fine with gecko except no charge pump, I haven't got it all installed just a dry run.
    I can see from these posts I'll have the same problem no ECP manual overide.
    So options New PC, Smooth Stepper or the C26.
    by far the cheapest option is the C26 so is it any good ?
    have you had any problems running it. did it work straight away, have you got this working with a VFD ect.
    Would love some input before I comit again to more kit to get things running.
    Never ending money hole this lark
Page 1 of 2 12
  1. Usb SS + G540, charge pump question?
    By draughted in forum SmoothStepper Motion Control
    Last Post: 03-15-2014, 07:12 AM
  2. G540 charge pump & Mesa 5i20
    By cartula in forum Gecko Drives
    Last Post: 04-29-2011, 05:05 AM
  3. anybody know of a pci db25 card that works with charge pump signals?
    By landmark in forum Waterjet General Topics
    Last Post: 06-13-2010, 05:24 AM
  4. G540/Mach3 charge pump fault LED is lit
    By will gilmore in forum Gecko Drives
    Last Post: 04-13-2010, 02:26 AM
  5. G540 charge-pump not pumping
    By aystarik in forum Gecko Drives
    Last Post: 05-14-2009, 08:38 PM
