587,104 active members*
4,339 visitors online*
Results 1 to 11 of 11
    Jan 2008
    9
    I need a lathe post for gibbscam
    I need a lathe post for gibbscam, can anyone help out?? The control is a MSC-500 it is like a regular Fanuc type G&M code. So any lathe post will be fine. I will edit it if necessary with posthaste.
    Jan 2008
    9
    I meant to say I will edit it with compost, for all the post buffs out there.
    Apr 2007
    126
    Email ME
    Send contact info most any fanuc OM /MT will do!
    Jan 2008
    9
    Thanks I know most any will do. I did manage to get one that is close. Would you still please send me what you have to: [email protected] Thanks alot Jim!
    Feb 2009
    6028
    Msc500 is Fanuc 21 or 21i
    Jan 2008
    9
    MSC-500 is just like 21I, come on dudes, I need that post. I want one that starts like this if possible:
    O4545( STAINLESS STEEL SHAFT.NCF )
    ( STAINLESS STEEL SHAFT A REAL DEFEATER
    ( 7/23/10 AT 7:37 PM )
    ( OUTPUT IN ABSOLUTE INCHES )
    ( OPERATION 2: ROUGH )
    ( TOOL 5: 0.03125 RAD. 80-DEG. DIAMOND )
    ( 432 CNMG STYLE ROUGHER )
    N1
    G99G54
    G30U0.
    G30W0.
    G50S850
    G97S734M3
    G0T0505
    G0X3.Z.075M8
    Z.045
    X2.015
    G1X1.432F.01
    G96S275
    Z-.0052
    G3X1.4504Z-.0125R.0513
    G1X1.547Z-.0608
    G3X1.562Z-.0703R.0513
    G0Z.0385
    X1.3628
    G1Z.0025
    X1.3779
    G3X1.432Z-.0052R.0513
    G1X1.4968Z.0272
    G0X1.4983
    X1.8852Z-.1663
    Z-4.3249
    G1X1.885Z-4.325
    Z-4.5133
    X2.Z-4.5708
    G3X2.015Z-4.5803R.0513
    G0Z-4.325
    X1.755
    G1Z-4.4483
    X1.885Z-4.5133
    G0Z-4.325
    X1.625
    G1Z-4.3833
    X1.755Z-4.4483
    G0Z-4.3251
    X1.577
    G1Z-4.3692
    G3X1.6234Z-4.3825R.0513
    G1X1.625Z-4.3833
    G0X3.
    Z.075
    G97S365
    G30U0.M9
    G30W0.M5
    G0T0500
    M1
    ( OPERATION 3: HOLES )
    ( TOOL 9: 0.468 DIA. DRILL )
    ( .468 TWISTDRILL )
    N2
    G99G54
    G30U0.
    G30W0.
    G50S850
    G97S650M3
    G0T0909M8
    G0Z.075
    X0.
    G1Z-2.005F.003
    G0Z0.
    Z.075
    G30U0.M9
    G30W0.M5
    G0T0900
    M1
    ( OPERATION 4: ROUGH )
    ( TOOL 11: 0.01563 RAD. 80-DEG. DIAMOND )
    ( 21.51 CCMT STYLE ROUGHER/FINISHER )
    N3
    G99G54
    G30U0.
    G30W0.
    G50S850
    G97S850M3
    G0T1111M8
    G0X.468Z.075
    Z.0775
    G96S275
    G71U.016R.016
    G71P4Q5U.015W.0025F.01
    N4G0X.6574
    Z.075
    G1Z0.
    X.6488
    G2X.5984Z-.0104R.0356
    G1X.5219Z-.0487
    G2X.501Z-.0739R.0356
    G1Z-1.8656
    N5X.468
    G0Z.075
    G97S850
    G30U0.M9
    G30W0.M5
    G0T1100
    M1
    ( OPERATION 6: CONTOUR )
    ( TOOL 7: 0.03125 RAD. 55-DEG. DIAMOND )
    ( 432 DNMG FINISHER )
    N6
    G99G54
    G30U0.
    G30W0.
    G50S850
    G97S813M3
    G0T0707M8
    G0X3.Z.075
    Z-.0449
    X2.015
    G1X1.6451F.01
    G96S350
    X1.5478Z-.0735
    G2X1.532Z-.0633R.0513
    G1X1.4354Z-.015
    G2X1.3629Z0.R.0513
    G1X1.4754Z.0331
    G0X1.4887
    X1.6433Z-.0442
    Z-.0454
    G1X1.5478Z-.0735
    G3X1.562Z-.0995R.0513
    G1X1.6548Z-.0722
    G0X1.6723Z-.081
    Z-4.3375
    G1X1.562Z-4.37
    Z-4.3717
    X1.6748Z-4.3385
    G0X1.6767
    X2.0981Z-4.5492
    Z-4.5549
    G1X2.0008Z-4.5835
    G2X1.985Z-4.5733R.0513
    G1X1.6084Z-4.385
    G2X1.562Z-4.3717R.0513
    G1X1.6626Z-4.3421
    G0X1.672
    X2.0963Z-4.5542
    Z-4.5554
    G1X2.0008Z-4.5835
    G3X2.015Z-4.6095R.0513
    G0X3.
    Z.075
    G97S465
    G30U0.M9
    G30W0.M5
    G0T0700
    M1
    ( OPERATION 7: CONTOUR )
    N7
    G99G54
    G30U0.
    G30W0.
    G50S850
    G97S850M3
    G0T1111M8
    G0X.468Z.075
    Z0.
    G1X.6488F.01
    G96S350
    G1X.5219Z-.0487
    G1Z-1.8656
    G0X.468
    Z.075
    M9
    G97S850
    G30U0.M9
    G30W0.M5
    G0T1100.
    M30
    Also notice the R values in the G02, G03 lines they are not I J and K values, so the preparatory commands and the G30's, G54's, and G99 are musts.
    I would appreciate anything that post close to this, in return I have I least 50 posts I can give, just give me a example of what you need and I will find something close.
    Thnx
    J
    Jan 2008
    9
    Please send posts to [email protected]
    that is jayz(underscore)[email protected]
    Thanks dudes!!!
    J
    Jan 2008
    9
    Okay whoever sent me the post: Fanuc OT MS(+G30)l212.82.1.pst was really, really close. I will have to take it.... I just don't like how it posts the G30 lines like G30U0W0; instead of like G30U0; then G30W0; like my example but that was close like I said..... anyone got it the other-way?
    Mar 2006
    158
    Dude -
    You said you had compost.
    That change should take you all of two minutes.
    Jan 2008
    9
    Dude, don't worry already done! check the dates of the post Man.... Thanks for nothing.
    Mar 2006
    158
    Dude -
    I did check the dates - no reply to if anyone had it "the other way".
    Typically when you want something for nothing - lol.
  1. Okuma Lathe post for Gibbscam
    By glider in forum GibbsCAM
    Last Post: 04-07-2009, 04:43 PM
  2. GibbsCam and Grooving-Lathe Module
    By Dull Tool in forum GibbsCAM
    Last Post: 06-11-2008, 02:36 AM
  3. Gibbscam Post
    By daewooevc in forum GibbsCAM
    Last Post: 04-21-2006, 10:41 PM
