587,453 active members*
4,348 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Anyone know of large CNC plans for sale?
Results 1 to 8 of 8
    Feb 2004
    17
    I am looking for available plans of a proven design of a large CNC mill to cut foam for scaled models of cars, boats, and jetskis. I need a working capacity of 8' X 4', and here's the most difficult part: at least 3' on the Z (yes feet). It would of course be helpful to have servo motor sizes and contoller setup designs as well.
    If anyone has worked on such a project, input would be helpful also.
    Everybody starts at the bottom.
    Nov 2004
    65
    http://www.inshorepowerboats.com/cnc.../CNCROUTER.htm
    dont see any problem with a 3 foot z , it just makes the project more expensive
    the best mods for the z would be round rails on support bar instead of just supported at the ends , and using split linear bearings on them , you would need to makke the z axis quite long on the fixed y axis because of the needed length and support needed ,
    but it is quite feasable without problems , pity I live in the UK , a nice large project .
    Dave
    May 2004
    600
    On the subject of large routers, does anyone here remember seeing a picture of a monster cnc router that in this particular picture it was carving a prototype (buck?) boat hull. The router seemed to be about as long and wide as a football field. Well not quite but almost. I seem to remember it as being in the US, that it had 4 or more axis. In the picture the product (in this case a boat hull) sat in a valley and the machine rails rode up on a higher section some +/-4m (12ft) above. I should have saved this link or picture and didn't. I've just finished going throught the more than one thousand photos here in the galleries and now it's "please help" time. Anyone got the link or photo?
    Skippy
    May 2004
    290
    I don't think this is what you are refering to but it seems to fit the bill nonetheless. I believe this cement structure will support the x axis...
    http://www.janicki.com/company/newsE...sBuilding4.htm
    Feb 2004
    2337
    Or was it this one skip http://www.cncmotion.com/titangallery.htm
    In my highly uneducated opinion, I recon this design looks unstable. The Z axis is so long that I recon it would have to move even if it was twice as thick.
    Being outside the square !!!
    Apr 2005
    25
    Thanks for this link. I found it and then couldn't find it again! This machine is pretty much what I'm looking for. I might look into getting the plans. I probably won't be able to help but alter them a little bit, but to have a finalized set of plans that has been thought through and then implemented can't hurt.
    35538
    Quote Originally Posted by skippy
    Skippy
    I think it's this one, but I know it's not the page you were looking for, that one had a much larger picture.
    http://www.janicki.com/products/marine/patterns.htm
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2004
    290
    Quote Originally Posted by ger21
    Ya, they've recently changed their site. Less hardcore now.
    ynneb, Your right about that Z looking unstable, but I don't think its intended to do anything more than foam or wax.
  1. New Plans to convert a Sieg Mini-Mill to CNC
    By rsteele in forum News Announcements
    Last Post: 09-19-2011, 07:18 PM
  2. Looking for people wanting to develop new plans for a cheap cnc
    By Hack in forum Open Source CNC Machine Designs
    Last Post: 02-17-2010, 11:15 PM
  3. Help to choose CNC Router Plans.
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 01-20-2010, 08:50 AM
  4. CNC Plasma table plans
    By krazycnc in forum Waterjet General Topics
    Last Post: 05-06-2005, 03:51 AM
  5. Cnc Router table Plans and ideas
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 11-13-2003, 03:12 PM
