Hello Guys.
Just joined the group.
I am looking to build a CNC Router to cut boat kits and the machine needs to handle a 2440*1220 plywood sheet. Cutting thickness will vary between 3mm to 20mm, mostly 12mm and less.
I have looked at the following:
1. Machine Tool Camp
2. CNC Router Plans
3. Data-Cut.
The Data-Cut looks the best engineered but the plans are for a smaller unit. It states you can upsize but you have to do the upscaling yourself and determine the best method of moving the X & Y axis. This of course implies you have knowledge of parts available, extrusion sizes etc. I know sweet F@#* All about this.
maybe it is not as difficult as I imagine?...
The CNC Router plans looks great however the base and sides looks 'unfinished'. Maybe there are methods to make it more professionaly finished.
Most importantly the machine firstly has to perform the functions required, be accurate and easy to use. Secondly the parts can be readily obtained without too much outside machining required.
I hope I have given enough information for my requirements and I appreciate any help in pointing me in the right direction.
Cheers
