Originally Posted by
themil
I am not a programmer but it sounds like your programming is sound........I believe you have a problem with the machine not with the operation of it.
His programming could be sound but he had the wrong type of tap, a tap drill that was too small and inadequate lubrication; he is also working with a material that is sometimes difficult to tap as the properties vary even within the same length of stock and hard inclusions are not unknown in A36.
