587,485 active members*
3,178 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion good for retrofit?
Results 1 to 9 of 9
    I'd like to have a CNC mill. It seems like there is inexpensive iron out there with outdated or broken controls. I'd like to get a mechanically sound mill and use some geckos or other drives and mach3. This is strictly for hobby/prototyping etc not production.
    I see lot of mills with Centurion 1-5 controls. Anyone know the specs of the servos? Anything else to think about for hobby style retrofit?
    Will
    Aug 2005
    385
    The cent 5 is a good control, if you find one cheap that works, I'd leave it. I know you're after a broken one though, so if you get one and do this please post how you went about it, I'd like to do it to mine in the shop...
    EXIT 85 Manufacturing "The best custom wheels, period" (www.exit85.com)
    Experts in low volume, highly complicated, one-off forged aluminum wheels
    I'll be sure to document. I want to know if I can reuse the servos/encoders as that would cut down the cost a lot.
    Apr 2004
    5749
    We retrofitted a mill that had a Centurion IV control
    We ended up scrapping the motors as well as the old amps, drives, computer, keyboard and monitor. But Centurion controls went on lots of different machines. Our old Leadwell's motors were big but inefficient, with BEI encoders that were going bad, and we needed motors that were compatible with the new drives we installed. Depending on what you've got, and how you want to drive them, your existing motors might work, but don't count on it. It's usually better to start with an entirely new electrical control system, so that you don't end up chasing shorts in old wiring, at the mercy of disintegrating pieces of plastic, or faced with basic incompatibilities between drivers and motors.
    Andrew Werby
    www.computersculpture.com
    Quote Originally Posted by will gilmore View Post
    hmm I was thinking that people often did retrofits of CNC machines and used the existed servos.
    Jan 2007
    206
    Smile Esab torch
    Just retrofitted an Easb CNC Torch with camsoft. Some one let the special smoke out of the servo drive board so I purchased the new RUBY drive from Servo Dynamics. very easy to set up and program, will work with brush or brushless servo. If you find old Milltronics Iron check with them for an upgrade control kit. With CamSoft software, Galil motion board, desktop PC,monitor, breakout box, control panel with hardwire buttons, 3 new servo drives, and other items NOT COUNTING TIME AND LABOR, I had $9,500.00+ and still not where I want to be.
    If Milltronics built it, they have all records and can put together a kit to upgrade to current technology using old servos with maybe only changing drives and getting new wiring harness. A direct plug and machine will take away about 10 grand in headaches and frustration and you will have a good machine that has ability to make money every day with out some goofy glitch bringing it to a halt.
    Good Luck
    The Farmer
    I'm not a machine shop. I would like to make some parts that will make some money but I'm not going into this thinking of this machine as an investment.
    just found these specs on ebay for a Fryer with Centurion 1:
    Servos: Milltronics Type- MT30M4-38 NO- S06279 C/Stall Torque -26 LB/IN 8.6 A Max -3700 RPM 140 V47
    sound right? 8.6A 140V?
    Mar 2006
    96
    I'm doing a Milltronics retrofit right now. Keeping old motors. About half done. Using Ajax with Mach3.
  1. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
  2. camsoft retrofit to a anilam crusader retrofit
    By bowlingmac in forum CamSoft Products
    Last Post: 07-25-2008, 03:00 AM
  3. good base manual milling machine for future retrofit
    By hansw3 in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2007, 01:21 PM
  4. Centurion 5 vs. Centurion 6 and validation codes
    By Turbo VW in forum Milltronics
    Last Post: 02-11-2007, 09:35 PM
  5. Centurion 7
    By Enda in forum Milltronics
    Last Post: 01-26-2006, 01:00 AM
