587,482 active members*
3,420 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > good base manual milling machine for future retrofit
Results 1 to 2 of 2
    Oct 2007
    15
    Question good base manual milling machine for future retrofit
    For hobby purposes I am looking to purchase a manual vertical mill. What would be good machine (bridgeport or equivalent quality) to get with intentions of CNC retrofit in future? I see there are different types of bridgeports. Are certain ones more challenging to modify(ball screw, acme screw, etc.)
    This will be hobby in my home with very low cash flow. I figure I can add onto it as I see fit. This will avoid having to make larger investment at one time that I cannot do. Any comments appreciated!
    Feb 2007
    1084
    I've purchased Bridgeport mills in decent condition for $2K. The import versions aren't worth the savings. You can't get parts for a lot of them and they aren't as ridgid as a genuine bridgeport. If you watch ebay and look around your local area, you'll be suprised where you will find a Bridgeport looking for a new home.
  1. Good base milling machine to add onto in future?
    By hansw3 in forum Benchtop Machines
    Last Post: 11-01-2007, 05:30 AM
  2. Witch milling machine to buy for CNC retrofit?
    By Sperstad in forum Vertical Mill, Lathe Project Log
    Last Post: 02-10-2007, 05:21 AM
  3. Machine interfaces of the future using this technology???
    By ynneb in forum Community Club House
    Last Post: 07-14-2006, 08:50 PM
  4. How to decide if an old milling machine is good?
    By crazyman in forum Knee Vertical Mills
    Last Post: 05-02-2006, 02:57 AM
  5. Why is a heavy iron base vital for a good machine?
    By Com in forum Mechanical Calculations/Engineering Design
    Last Post: 11-29-2005, 04:41 PM
