587,370 active members*
3,253 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Gear functin in Ver 22
Page 1 of 2 12
Results 1 to 20 of 36
    Jul 2006
    117
    Has anybody worked with the gear function in Ver 22? I can't figure out how to use the standard terms as in Ivan Law's book and get them to fly in BobCad 22. Ver 20 takes the terms and computes the tooth shape very well but ver 22 balks at each turn. When I look at the terms the default gear has I find no standard formula from any of my gear books that give those values, but BobCad makes a gear drawing with them.
    GeneK
    Jan 2006
    4396
    No idea over here. Addendums, and Dedendums, Pressure Angles, and Pitch are what I go by when working with Gears. Sorry
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2006
    117
    gear function ver 22
    Quote Originally Posted by tobyaxis View Post
    unfortunately machinist buy gear cutters by diametrical pitch and pressure angles and number of teeth. Model engineers and other make their drawings accordingly. I found a way to find the OD then convert that to the 'pitch' value that ver 22 wants entered using the pd given on drawings that I am converting to CNC. At least now a gear drawn in Ver 22 will over lay exactly a gear in ver 20.
    GeneK
    Jan 2006
    4396
    Quote Originally Posted by GeneK View Post
    GeneK
    Your not alone. I have been reverting back to V21 for a great deal of things that do not work in V22/2007. It's a shame really. Oh well, at least there is a fighting chance since I have switched to Alibre V10 Professional for CAD Modeling. I feel bad mentioning this because there are so many that purchased V22 that doesn't work are stuck on simple things that V21 can do.
    This was a very bad move on BCC's part. Chalk up another dissatisfied customer(nuts). I have grown very tired of this version and the excuses made by BCC. The only useful tools I got out of it was Predator Virtual CNC, Predator Editor and a few extra file translators. Hmmmmmmmm.........
    "Kick the Tires and Light the Fires.......Alibre ROCKS!!!!!!"
    http://www.cnczone.com/forums/showth...300#post438300
    http://www.novedge.com/MecSoft/Visua.../products/1572
    Toby D.
    Schwarzwald
    Mar 2008
    163
    Maybe you just need some training for V22 Toby. Afterall you still have question about V21
    Jan 2006
    4396
    Quote Originally Posted by HMB3000 View Post
    Run out and get training for broken software, that is funny. Hmmmm...., I wonder if you know what your actually saying, or you have posted just to start trouble.
    Personally, when I need training for CAD/CAM software I will be going elsewhere, because this is ridiculous.
    FYI, My question about V21 has been answered buy a pc expert, and good friend SWAG. He figured it out playing around with the fonts.
    So what is it that you do?????
    FYI: I am the only person that was able to create Kiwi's Dome with V21, LOL. But then again V21 works, and Alibre is way better.
    http://www.cnczone.com/forums/showthread.php?t=11350
    Toby D.
    Schwarzwald
    Mar 2008
    163
    it was only a sudjestion had no idea that your that touchie. did not mean to get you all worked up
    Jan 2006
    4396
    Worked UP???? To put it in another way I would say that BCC has been outgrown.
    Not to mention the need for Full 4 Axis and 5 Axis Indexing capabilities plus better tool path options. V17,V19,V20,V21 have been successfully used for the last 6 years. Now a change to fully parametric software is a must to avoid having to recreate entire Solid Models and Tool Paths when customers make revision changes. Doing three times the work is not profitable in todays market.
    Sorry to Offend but there is a lot of competition out there and I plan to stay competitive.
    Anything can be done with BCC, but it can be very time consuming. Hence time is money.
    GeneK, I apologize for taking this thread off topic. If you would like I will move it to a better location.(wrong)
    Toby D.
    Schwarzwald
    Jul 2006
    117
    gear function
    No problem, apology accepted. I have always respected how clearly you have helped others on this and other boards. Fortunately/unfortunately for me I am not in a comercial endeavor. I'm a retired EE and certified watchmaker. Retired means very little money to try various programs. I need to make what I have got work at least as long as I can keep doing my hobbies. I was hoping for a migration to ver 22, but it looks like I'll also have to run both for quite a while.
    GeneK
    Jun 2004
    42
    Hey,
    Sounds like you folks think Bobcad V-22 and Microsoft's Vista go hand in hand. Both new and great.<grin>
    Calm Down
    Feb 2007
    77
    When I was an automotive mechanic, a very wise older fellow told me something; "New means new. New does not mean good." He was speaking of car parts, but I do believe that it pertains to just about everything.
    However, with a lot of work on my post processor and figuring out what I need to do to get around certain issues, I can use v22. I have not found a way to do this with Vista.
    Jan 2006
    4396
    Quote Originally Posted by smurph View Post
    I have been using V22 since last year for tons of stuff. The only problem has been having to revert to V21 and Previous Versions of V22 to keep things going.
    It has out worn its welcome on my PC's and for my business. Better software is needed at this point.:drowning:
    Toby D.
    Schwarzwald
    Jul 2006
    117
    Quote Originally Posted by Toolbit View Post
    Hey,
    Calm Down
    No, just some workmen discussing tools.
    GeneK
    Jan 2006
    4396
    Hey,
    Calm Down
    Is there really any point to this post? Lets try to be a little more compassionate and helpful.
    Anyone can knock something, but can they actually help?
    Toby D.
    Schwarzwald
    Jun 2004
    42
    tobyaxis,
    I didn't think there was a negative remark in my post. I did say that V22 and vista was new and great! Maybe you should go back and read your posts about V22, those were the only negative remarks that I read about Bobcad V22.
    Since you're slightly touchy on this subject I'll apologize for saying that "V22 and Vista are new and great", and "calm down". Maybe I should of said "slightly tarnished". At least it could then be said that "I wasn't being compassionate". Buttttttttttttt I really did want to say that "V22 and Vista are new and great" Soooooooooo I guess you're opinion that I'm not compassionate stands.<grin>
    Aug 2003
    449
    GeneK,
    I know that this thread has digressed from the original question, but I would like to make sure that you are getting an answer and not just rhetoric.
    You will have to forgive me, but I do not have a copy of Ivan's Law, so I am going to have to ask: What values do you have to work with?
    If you can tell me what values you have, I can give you a solution to input the values that are required and get the proper output from the system.
    Regards
    Jul 2006
    117
    Quote Originally Posted by The One View Post
    GeneK,
    Regards
    The One, I'm sure that Ivan Law who wrote Gears and Gear Cutting for the Workshop Practice Series(ISBN 1-85242-911-8) is flattered that you have promoted him to having it proclaimed a LAW!(;-).
    The confusion comes in the fact that for gears there are three terms that include 'pitch'.
    Pitch is never refered to by itself in most books, when I'm talking gears with my friends we have already established diametrical pitch, pressure angle and number of teeth. Those three terms define any standard gear. Those three terms are what will be on the face of the drawing to tell you what is needed. I can buy or make a cutter from those terms and make a gear for some one on the other side of the world and they will mesh.
    The confusion comes from the default values in BobCad not jiving when run through the standard formulas.
    I took the only fixed information from that window and finally figured out what values each window needs.
    It seems that who ever set up the example made a quick conversion from a module 6 gear and used rounded off values. It winds up that the 'Pitch' window needs Pitch diameter, not Circular Pitch or Diametrical Pitch.
    The conversion from module makes a diametrical pitch of 4.2353, confusing in that diametrical pitch is always an integer. (module is used mostly with metric gears) Check any catalogue such as MSC for involute gear cutters and you will see only integer values for the cutters that can be bought. Next the value of pitch diameter in the example is off by 28 thousanths of an inch, in this day of the calculator that is a huge round off error and causes gears to have an extra half tooth at times.
    Ideally, I should have to only enter the standard values I would give to my gear supplier to order a gear, # teeth, diamatrical pitch, and pressure angle. For those in the metric countries would require # teeth, module, and pressure angle.
    GeneK
    PS, the above only relates to involute gears, cycloids are another kettle of fish.
    Oct 2007
    142
    I'm afraid to try another CAD program. All I know is bobcad and I kinda like it. After months of (nuts) If I try another and like it.......
    Toby are you still going to help out us diehard bobers?
    Jan 2006
    4396
    Quote Originally Posted by orizaba View Post
    I have every intention of helping.
    I must apologize for my personal rant do to a Troll in the Forum and he knows who he is. This individual has nothing better to do than Troll Forums and start trouble. But that is ok because if it is a continuing problem the little RED Button in the top left corner will be used again.
    I must tell you though that Alibre has become the CAD program that I use now.
    Help will aways be here and I will continue to try to help as much as possible.
    Have a nice weekend:rainfro:
    Toby D.
    Schwarzwald
    Oct 2005
    859
    I have also asked Bobcad to update their gear module but I want the other way instead of what you want. I wish to have more control (and yes it needs to be accurate). The reason is we wire cut specials that do not get carried as standards from any known gear manufactures. We actually produce flat broaches for many automotive spines and their gages too. When they wish to have a gage within +-.00005 over pins(nearly imposible by any gage company because they can never repeat a certification) we ussually have to make several at the same cut and hope one certifies in tolerance.
    We have a wire program from years back called Mecanic. It had the best gear addon involute module I have ever saw. It is based on metric Module input but the conversion is easy for inch. It even gives the formulas for converting. It also allowed to change the form based on many gear specs. Believe me when I say many but most were measurement over pins and modified diameters.
    Anyhow the point is that many CAD programs out there do not create correct involute gears. Mecanic would even create an involute based on a tolerance amount. So I could tell it to give the correct form within .001" or .00001" and the geometry would be less or more complex accordingly.
    It always made the gear form out of tangent arc segments and not lines like many programs do. Arc segments are the prefered (more correct) way for smooth form and ease of form creation.
Page 1 of 2 12
  1. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  2. Spur Gear / Gear Rack
    By ckrantz in forum Linear and Rotary Motion
    Last Post: 12-07-2006, 06:06 AM
  3. What gear oil are you using?
    By KEYTEEM in forum Charter Oak Automation Support Forum
    Last Post: 02-24-2006, 06:16 PM
  4. Should I gear
    By rocks101 in forum Stepper Motors / Drives
    Last Post: 07-15-2005, 04:00 PM
  5. gear mfj
    By pyroracing85 in forum Waterjet General Topics
    Last Post: 01-15-2005, 12:40 PM
