587,189 active members*
3,175 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How do you hold down a sheet of alum?
Results 1 to 6 of 6
    Jul 2006
    22
    I was just looking through this forum and...
    I was wondering how do you hold down a sheet of alum. Say if the size was 4x8' .080 and you wanted to cut a part out of it that is 3.5'x3.5'. Do you use clamps and just hold down the outer edge on a sheet of MDF or plastic?
    35538
    vacuum, double face tape, spray glue.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2007
    71
    Id say double stick tape (thin kind) but getting the work off the table without it bending seems like it would be an issue. I guess you just go slow with a putty knife.....
    soon to be cutting .090 alum myself let us know how you do!
    ~Steve
    May 2005
    219
    You can use rubbing alcohol or acetone or some other solvent to unstick the double sided tape. I just let it wick into the tape and it usually comes up with no problems. You'll have a sticky mess to clean up from your table and work piece though.
    Dec 2006
    532
    vacuum is by far the easiest/most professional way of holding something like that down.
    Jun 2007
    3734
    Cool Another way..
    Quote Originally Posted by UBRacing View Post
    Put a piece of MDF more than covering the area to be used.
    Clamp it down. Rout through the MDF. Minimal burs this way.
    Thin MDF underneath allows sharp part of cutter to leave nice edge on the bottom. This is similar to what PCB manufacturers do.
  1. A Few Alum Plates Needed
    By elogicca in forum Employment Opportunity
    Last Post: 05-30-2007, 10:57 PM
  2. Milling Alum.
    By Smackre in forum MetalWork Discussion
    Last Post: 11-23-2006, 02:10 AM
  3. RFQ for Billet Alum. piece
    By crazyknight in forum Employment Opportunity
    Last Post: 11-04-2006, 01:40 PM
  4. Alum Angle
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 05-13-2005, 12:49 PM
  5. Help!! Machining Alum with a cnc router.
    By duraflap in forum MetalWork Discussion
    Last Post: 04-01-2005, 03:40 PM
