587,475 active members*
3,710 visitors online*
Results 1 to 20 of 21
    Jan 2006
    4396
    Geof is it safe to assume that a Haas Lathe will cancel the last offset like this:
    G0G40G80G99M5
    G28U0W0M9
    G50S2000M41
    T0100M8<<<<<<<<<<<Tool Index
    G96S750M3
    G0X1.25Z.1T0101>>>>>>>>>Tool 1 Offset 1
    G41G1Z0F.025
    X0F.006
    Z.075
    G40G0Z1.5
    T0100>>>>>>>>>>>Cancel Offset
    G0X1.25Z.1T0121>>>>>>>>>>>Tool 1 Offset 21
    G71P10Q20U.01W.008D500F.01
    N10G41G0X.4
    G1Z0F.006
    X.5Z-.05
    Z-1.0
    N20X1.25
    G40G0 Z1.5M9
    T0100>>>>>>>>>>>>Cancel Tool Offsets
    G28U0W0
    etc.
    etc.
    I found that Canceling the last offset has fewer problems than calling a new one. Provided that the tool is in a safe position to cancel the last offset (at least 3 times the nose radius away from the work piece).
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2005
    12177
    Quote Originally Posted by tobyaxis View Post
    Geof is it safe to assume that a Haas Lathe will cancel the last offset like this:...
    You have caught me here. I don't know because I never bother cancelling offsets. I suppose to be picky I should and if I missed setting the offset for a new tool it could give me a crunch. However, on the lathe the offset call is in the tool change command Tn0n so it is difficult to miss. I suppose on the mill it would be easier to miss because it is a separate G43 H0n command but so far I have been lucky.
  1. Grid Shift
    By scuba in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2013, 02:10 PM
  2. Datum Shift with TNC530
    By Bubbles in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-20-2006, 11:23 PM
  3. Gang tool cnc mini?
    By Call Maker in forum Mini Lathe
    Last Post: 03-26-2006, 06:38 PM
  4. offset shift and part off
    By nitemare in forum Daewoo/Doosan
    Last Post: 03-04-2006, 04:49 AM
  5. Anyone need help on 3rd shift??
    By AMCjeepCJ in forum Milltronics
    Last Post: 12-22-2005, 08:34 AM
