587,510 active members*
3,694 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > engraving anodized alum
Results 1 to 5 of 5
    Feb 2007
    71
    hello all, I am planning on engraving some aluminum panels, anodized dark blue. and or black. I will need letters ranging from .125 up to .250 tall, just deep enough to expose the shiny metal. I plan on using rotary bits, but would like to try diamond dragging as well (if the bits are reasonable -$)
    any tips on depth/speeds, bit angles etc. basically I need to know where to start my experimenting. I have a laminate trimmer 30k rpm.. should I get one of the cheap router speed controls?
    And with the diampnd drag, how do you set the drag pressure - spring loaded tool holders? or do you set the Z to go say .002 -.005 below the surface?
    diy cnc router, mach3. want to get the vectric software.
    newb here thanks for any tips or starting points!
    ~Steve
    Mar 2007
    39
    Quote Originally Posted by srmaietta View Post
    ~Steve
    Hi Steve, I used the diamond drag method utilizing a 1/8 shank diameter diamond dressing tool from our grinding dept. and mounted it into the spring loaded tool holder. Worked great!
    Feb 2007
    71
    Thanks 5S dude for the reply. What spring loaded holder are you using? Should I worry about my non lockable spindle messing up the engraving? Does the drag process put heavy side loads on the spindle bearings that I should worry about in the long run?
    thanks
    ~Steve
    Mar 2007
    39
    thanks
    ~Steve
    Hi Steve,
    I use the spring loaded engraving holder from “2L inc. P.O. Box 105 Hudson, MA 01749 (978)567-8867” http://www.2linc.com/engraving.htm
    It works awesome and with the adjustable spring tension there is very little side load if any. I typically program a Z-.007 to .010 deep with a feed rate of F50. to F100. inches per minute and the engravings come out razor sharp. On my V2XT, I place the spindle in neutral and program a spindle speed of S750 because there is a safety interlock that won’t let the X & Y axis move with out a spindle speed.
    Feb 2007
    71
    thanks for the info man!!!!!
    ill have to look for the spring loaded tool holder.
    cant wait to get going!
    ~Steve
  1. Engraving anodized aluminum - color fill?
    By Neil_J in forum Hobby Discussion
    Last Post: 09-17-2008, 03:11 AM
  2. Laser etching anodized aluminium
    By Fred Nerk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-02-2007, 02:51 PM
  3. Milling Alum.
    By Smackre in forum MetalWork Discussion
    Last Post: 11-23-2006, 02:10 AM
  4. Anodized Aluminum Round Rod - Best Place To Buy It?
    By nlh in forum Material Machining Solutions
    Last Post: 12-02-2005, 04:54 PM
  5. Alum Angle
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 05-13-2005, 12:49 PM
