587,453 active members*
5,871 visitors online*
Page 3 of 6 12345
Results 41 to 60 of 111
  1. #41
    Oct 2009
    836
    Re: A Desktop CNC by David A
    Place ball screw drive onto the carriage.
  2. #42
    Oct 2009
    836
    Installed drive.
    Attachment 505376
  3. #43
    Oct 2009
    836
    Install brace bracket.
  4. #44
    Oct 2009
    836
    Install first brace.
  5. #45
    Oct 2009
    836
    And the second one.
  6. #46
    Jul 2018
    6471
    Hi David - Can you give a brief description of how you do your imaging? I'ts always impressed me.. . Peter
  7. #47
    Oct 2009
    836
    I have a set of 23 sized ClearPath servos so I will use them.
    For steppers, you can use larger pulleys for higher speeds.
    Servo installed.
    Attachment 505390
  8. #48
    Oct 2009
    836
    Hi Peter, I use an app called Pixelmator Pro for the graphics but you can do the same with Photoshop as well.
    In a nut shell, you create different layers which are stacked on top of each other.
    Let's say you paint the bottom layer yellow. Then on the layer on top of it, you cut out the areas where you want the yellow to show through. Then you put a new layer on top of the second layer and select areas you want to put on a different color. And then you adjust the opacity of each layer to get the effect you want. On some images, you have tens of layers with all their own adjustments and it can become very tedious very fast.
    It's very different from a CAD program as they are pixel based and not vector. When you enlarge enough a pixel based image, you will be able to see the actual pixels, contrary to a CAD software where a line is always a line no matter how much you enlarge it. And there is always, forever something more to learn with Pixelmator and Photoshop.
  9. #49
    Jul 2018
    6471
    Hi David - Thanks I have a look at Pixelmater don't have photoshop or anything like that. Peter
  10. #50
    Jul 2018
    6471
    Arrggg its for a Mac!
  11. #51
    Oct 2009
    836
    Oh, I didn't realize that. You buy the Pixelmator and you own it. With Photoshop, you pay a subscription forever. But I think there is a basic version of Photoshop you can buy.
  12. #52
    Oct 2009
    836
    Install linear rails on the gantry beam.
    Attachment 505544
  13. #53
    Oct 2009
    836
    The X/Z Carriage
    Linear rails: 2 x 1.18 diameter (30mm) stainless steel round rails
    Space between spindle and face of gantry: 0.85"
    Motor size: Nema 23
    Lead: 4mm per revolution
    Speed: Up to 157 inch/minute @ 1,000 RPM
    Dynamic/static rating: about 600lbs/1,000lbs
    Max. speed: 3,000 RPM
    Some time ago, concept for the X/Z carriage was published.
    Attachment 505546
  14. #54
    Oct 2009
    836
    This is the physical build.
    Colors to match concept
    Attachment 505548
    And without colors.
  15. #55
    Oct 2009
    836
    The back side.
  16. #56
    Oct 2009
    836
    And the stepper/servo mount installed.
  17. #57
    Oct 2009
    836
    Spindle installed.
    A water cooled spindle in this case with plumbing/wiring guide.
    Attachment 505610
  18. #58
    Oct 2009
    836
    Standard lighting and Loc-Line.
  19. #59
    Oct 2009
    836
    Ready for installation onto the 3060 gantry beam.
    Note that the spindle back is just 0.85" in front of the gantry beam face.
  20. #60
    Oct 2009
    836
    X/Z carriage on the gantry beam with the servo installed.
    Attachment 505694
    Attachment 505696
Page 3 of 6 12345
  1. David A's Benchtop CNC Version 2
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 09-09-2021, 02:08 PM
  2. Replies: 0
    Last Post: 06-06-2018, 01:50 PM
  3. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum For Sale Only
    Last Post: 09-18-2015, 09:05 PM
  4. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum News Announcements
    Last Post: 04-28-2015, 11:23 AM
  5. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
