Faced with the prospect of scratching out my missing aluminum motor mount on a very small CNC machine, my progress on the Bridgeport had stalled. Having a very busy life made this little excuse enough to delay any effort.
Then I had a breakthrough -- a few simple realizations that were enough to get me motivated again:
1. This part really doesn't need to be aluminum, or even acrylic. It's under very little stress.
2. I can cut the part from MDF and have it done in an hour or so!
3. The design of the bracket is already done. All I need to do is make it.
Cutting the part from aluminum would take a long time: 6+ hours on the small machine available! I also could not find a suitable piece of aluminum stock to cut the part from. That was enough of a mental barrier to keep me from attempting the build. I had "builder's block!" You know, like writer's block. And so the project sat.
The idea that I could have the part in my hands in an hour changed my electronic design into reality. It was very satisfying to make chips again, even if the chips were really just MDF dust. The part bolted up perfectly, toleranced just right for a snug, but not permanent fit with the locating circle on the NEMA 42 servo motor. The bracket can also accept a NEMA 34 motor, if I need to change my mind again.
Another nice discovery -- the bracket fits! Someone asked me for the CAD models of this design a few months back, but just before I sent the models, I realized that the "star" points of my design would probably interfere with the vari-speed housing on the spindle! So I didn't send the models, thinking the design needed more adjustment. If you're following this thread and still interested in the IGES or Pro/E models, please PM me.
Of course, there is a new stopper: My helical coupling fits a 1/2" motor shaft, which is what the NEMA 34 motor used. But the NEMA 42 motor needs a 5/8" coupling. Fortunately, McMaster Carr has good prices and I was able to order one online. Hopefully it will be here on Tuesday. If you want to take a look, go to
www.mcmaster.com and type in "6208K14" which is the P/N.
