Re: Spindle Recommendation
Originally Posted by
Phil_Par
Would this set up: 30A at 220v would give me the opportunity to power all my electrical needs?
From the same 220v circuit, 220v would go for the spindle and 120v would go for the spindle water pump, vacuum and controller box where all the PSUs are.
There was a different post that mentioned this set-up as being unbalanced. Is that bad?
The alternative is have two different circuits: one 220v 15A for the spindle and a separate 120v for the other components
Sent from my SM-G970W using Tapatalk
I ran one circuit for 120 volt for the control side and used a 30 amp 240 volt to feed my spindle VFD. You could run 4 wire 240 volt and split off the 120 volt with a neutral wire. Most shops are not wired that way to the 240 volt outlets however. You must run a white or neutral wire and a green equipment ground from your panel and not tie into the green for your neutral. That was banned years ago. Exceptions are for the old style electric stoves.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
