Re: Servo motor with encoder drifting- need help
Yes, A+ to +MAZ, A- to -MAZ, B+ to +MBZ, and B- to -MBZ.
Note, when you do this you may have to change your CEZ value. Also, this should double the PPR. I recommend that when you make this change that you mechanically disconnect the servo from the axis, or set your TLZ to a low value, maybe 0.5 or so. Just to make sure the motor doesn't run away when you make this change. Once you are sure the motor is under control, then you can set the TLZ back to normal.
Jim Dawson
Sandy, Oregon, USA
