587,775 active members*
2,882 visitors online*
Thread: Cheaper ATC?
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Aug 2016
    132
    Quote Originally Posted by kstrauss View Post
    Do M100/M101 actually actuate the PDB on a machine without an ATC or is the USB I/O board required?
    M100/M101 are generic M codes in LinuxCNC, with user specified functionality. For the USB I/O board, M64 P1 and M64 P0 would be used to turn on/off an output. You could use it for a DIY drawbar if you wanted.
  2. #22
    Apr 2013
    1788
    Re: Cheaper ATC?
    Quote Originally Posted by footpetaljones View Post
    I understand that the USB I/O board could be used to activate a PDB. My question was: "Is additional hardware required to activate the Tormach PDB on a machine without the Tormach ATC installed?".
  3. #23
    Aug 2016
    132
    Re: Cheaper ATC?
    M100/M101 needs to activate a relay to fire the PDB. Whether the relay is on the USB I/O board or an ice cube doesn't matter.
    And a solenoid that the relay is wired to. I think tormach uses a 5 port/2 way solenoid.
  4. #24
    Jun 2012
    311
    Re: Cheaper ATC?
    kstrauss,
    I believe you will need to USB I/O board. AFAIK there are no I/O ports in the controller that can be controlled using custom macros.
  5. #25
    Apr 2013
    1788
    Re: Cheaper ATC?
    Quote Originally Posted by IMT View Post
    kstrauss,
    Thanks! That was my assumption but I just wanted to be certain that I had not missed something.
Page 2 of 2 12
  1. Any cheaper ways?
    By esadaddy in forum Digitizing and Laser Digitizing
    Last Post: 02-16-2009, 03:01 PM
  2. Cheaper Linear Carriage maybe
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 11-09-2008, 04:46 AM
  3. cheaper for a kit or buy plans
    By dgalaxy in forum Benchtop Machines
    Last Post: 07-02-2005, 04:17 PM
  4. Any Cheaper than this!
    By Al_The_Man in forum DIY CNC Router Table Machines
    Last Post: 05-02-2005, 07:56 PM
  5. Cheaper alternatives to SolidWorks?
    By dbassett74 in forum Uncategorised CAM Discussion
    Last Post: 10-14-2004, 07:14 PM
