Passive on the settings page.
I dont have the interface, I am wondering if I should look for one?
I am using it directly plugged into the accessory socket on the machine.
A standard din connector is what is used inside the probe to connect it to the transmitting section.
I am well pleased with it so far as this is my first experience with probing of any kind.
I did have to put in the backlash correction in Pathpilot as Brian mentioned earlier for the X and Y axes, then it was very accurate.
Good luck with your project!
