Originally Posted by
Scrambled1
You can drip feed to the hurco. I have two ultimax 2 machines and burned out both of the rs-232 boards in both. I am using a phase converter, and was told this was an issue. Some sort of voltage issue between the rs232 board and the desktop.
I switched to a gizmo from highlands dnc in Florida. I wired this into the power supply on the hurco's, and have had zero problems.
I just load the program onto the USB drive, install it to the gizmo, and read it out, and run.
If you want more info just let me know.
Steve
