587,925 active members*
3,424 visitors online*
Results 1 to 12 of 12
    Nov 2007
    90
    Drip Feeding?
    How can I determine if my Dynapath is equipped for drip feeding?
    It's a 10, but it may have been updated.
    The next question, if it is, is how do I set it up to do so. I am able to load programs from my PC via RS232 connection but I have no experience with drip feeding.
    I've been looking in the manual, but having no experience, I'm not even sure what I'm looking for!
    This is the setup screen for my software. I assume "Flow Control" will need to be configured?
    Thank You!
    Nov 2007
    90
    This may shed a bit of light on it.
    Is "Buffered Input" any indication?
    Oct 2006
    106
    'Buffered Input' is what DynaPath called drip-feeding. Check out the following page:
    DynaPath CNC Controls & Machine Tools
    Feb 2009
    6028
    From catalog page type program name RS232C. That puts it in "drip feed" mode.
    Nov 2007
    90
    Thank you very much!!
    Now I at least know that it should do it!
    Nov 2007
    90
    Got a glitch!
    When I follow the instructions on the Dynapath site and press the "Cycle Start" button, I get a "Premature End" Fault. I had not begun to send the data from the PC yet.
    This is on a program that I had previously loaded and executed earlier to make sure it worked properly.
    Any suggestions?
    Thanks!
    Nov 2007
    90
    When trying to send a program from the Dynapath to my PC, I am only receiving the last 16 lines of a 32 or 33 line program.
    It's communicating, or I wouldn't get any of it, but why just part of it?
    Any ideas what is happening there?
    I'm in the "trial and error" mode now, and it does not seem to make any difference how it is configured.
    Thank You!
    Dec 2005
    3
    Try lowering the BAUD rate to 4800. The BAUD rate must be the same on both the control and the PC.
    Nov 2007
    90
    It drip feeds!!! :banana:
    Just another dumb mistake...
    I had gone to catalog and typed in RS232 rather than RS232C.
    I was in a hurry and a bit frustrated, as I had to get a part done that was over 8000 lines of code and ended up breaking it up into 9 segments to get it done.
    Thanks to all for the replys!
    Jan 2011
    48
    Stuck on the X on X off Charicters for Dynapath
    :stickpokeCan anyone please tell me what the "x on and off" characters should be for the dynapath controllers. I am running a delta 20 with cimco and I don't know which one it uses to stop the transfer when my memory is full. Thanks
    Nov 2007
    90
    This is what I have at the controller
    This is what I have at the PC
    Dunno it is correct to the letter of the law, but both file transfer and drip feeding work fine.
    Feb 2010
    18
    hey guys, i know its an old thread...but I have a dynapath delta 40. i just recently got the harddrive setup and reading on the machine.
    but they realized that buffered input isn't enabled on my machine. dynapath wants $800 for the floppy disc which is insanely expensive
    does anyone have the executive drive floppy for this control with buffered input they wouldn't mind making a copy for me? thanks for any help
  1. Drip Feeding
    By widgitmaster in forum Polls
    Last Post: 01-28-2011, 09:02 PM
  2. drip feeding
    By stevieboy in forum HURCO
    Last Post: 04-21-2010, 09:05 PM
  3. drip feeding
    By stevieboy in forum Mastercam
    Last Post: 03-25-2010, 02:45 PM
  4. Drip Feeding
    By capital in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-08-2009, 12:19 PM
  5. drip feeding vtc-41
    By scottn in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-08-2007, 01:52 PM
