587,259 active members*
3,269 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Solidcam wow what a learning curve looking for paid advice [emoji4]
Results 1 to 9 of 9
    Mar 2016
    27
    I've been teaching myself to use solid cam for about 6 months wow what a steep learning curve
    I can get most things done but there is always some form of mistake .. Like gouging or the tool over travels the area I want to focus on ..
    Is there anyone that can review simulations or process and give direction or advice ?? More than happy to pay
    This is the kind of stuff I'm making.
    Oct 2013
    64
    Re: Solidcam wow what a learning curve looking for paid advice
    Nice one.
    Sent from my Nexus 5 using Tapatalk
    Oct 2013
    153
    In my opinion solidcam is the most easiest software to learn. There is a bunch of videos for it in YouTube
    Mar 2016
    27
    Quote Originally Posted by imachining-6061 View Post
    The you tube vids are good and they got me going but they don't a plain all the setting and I don't understand why I'm getting gouging but it's not visible in the simulation
    Practice makes perfect
    May 2015
    1422
    Not SolidCAM, but I found a lot of gouging issues came down to how I defined a retract surface and clearances for rapids. Once I got that sorted - and a lot more rigorous about checking it - I was in a happier place.
    If you can find a decent simulator that works on the actual posted gcode rather than just the CL output from the CAM and pay attention to it, it also helps you spot a lot of issues before they occur in metal.
    May 2014
    170
    No solidcam... Most times you have a dwell mark more then a goug. Leed in and out arcs and angles as mentioned. Another good button to look for would be "pass extension". Helical ramp diam as well.
    HSMWorks is the easiest and most intuitive cam I have seen. Even they do not explain this area in good detail. These kinda details are just hard to explain. So many variables and circumstances.
    Mar 2016
    27
    Cheers guys il defiantly pay more attention to the lead in and out I always leave those setting at stock . It's a pity the error doesn't show up on the simulation .... Il have to do some trail and error
    Mar 2016
    27
    So I think in wire frame mode on the simulation I can see some lines which shouldn't be there so I'm guessing there gouges ..??
    Looking at the part the gouge is occurring on the lead in so what should the angle and radius of the lead in be ?? It was at 10degrees and 2mm rad ??
    I carnt find any info on how these setting work or are applied ?
    Help anyone
    May 2014
    170
  1. Learning Curve
    By humbyrds777 in forum Community Club House
    Last Post: 05-29-2013, 02:11 PM
  2. Paid $25 start learning MasterCam
    By bonmotwang in forum Mastercam
    Last Post: 05-04-2011, 10:37 PM
  3. MC learning curve?
    By Ted Filley in forum Mastercam
    Last Post: 03-09-2011, 02:42 PM
  4. Learning curve!
    By IanH in forum Benchtop Machines
    Last Post: 06-01-2009, 02:36 PM
  5. What's the learning curve for the TL-2
    By rbest27 in forum Haas Mills
    Last Post: 12-18-2006, 05:29 PM
