587,579 active members*
3,406 visitors online*
Results 1 to 7 of 7
    Dec 2012
    194
    Machining Titanium pointers
    If you are interested in machining titanium or are experienced here is an article they may offer some pointers.
    Aerospace Manufacturing and Design - April 2016 - Titanium machining tips
    Mar 2009
    1863
    Re: Machining Titanium pointers
    I have learned over the years that titanium machines exactly like aluminum but at 10% of the speed and feed. But what do I know, I've only been machining since I was 15 years old. I'm 71 now.
    Dec 2007
    2134
    I was previously under the mistaken impression titanium was relatively easy'ish to machine, so the article was very interesting!
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Dec 2007
    2134
    Quote Originally Posted by Steve Seebold View Post
    So your running slow taking light or agressive cuts Steve? And I'm assuming carbide cutters or inserts? How does HSS cope if you've tried it?
    cheers, Ian
    Aug 2009
    610
    HSS does fine, BUT, your feed rates are so slow with it that you could probably take a vacation and come back when the part is finished. Cobalt drills and roughing end mills perform OK,but for any kind of speed you will want 4 or more flute carbide tooling. Preferably coated.
    Mar 2009
    1863
    Quote Originally Posted by aarggh View Post
    cheers, Ian
    High speed steel will work for one or two parts, but any more than that, I'd switch to carbide. Unless you're using really small cutters a Tormach won't go slow enough to use high speed steel.
    Mar 2013
    344
    When I was working at Douglas I had to drill titanium parts. Our method was cobalt drills, low rpm and heavy pressure. Worked okay, but we all hated working with Ti.
  1. Machining Titanium
    By pejaer in forum Tormach Personal CNC Mill
    Last Post: 05-17-2012, 07:59 PM
  2. machining parameters for TITANIUM FUSIONATED WITH MILDSTEEL(clading)
    By pachanga in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-06-2009, 01:44 PM
  3. Titanium Machining
    By vadimvc in forum MetalWork Discussion
    Last Post: 02-25-2008, 07:45 PM
  4. machining titanium
    By gaser25 in forum MetalWork Discussion
    Last Post: 10-26-2007, 12:39 AM
  5. Machining Titanium
    By newdogs in forum MetalWork Discussion
    Last Post: 05-11-2007, 01:37 PM
