If you are interested in machining titanium or are experienced here is an article they may offer some pointers.
Aerospace Manufacturing and Design - April 2016 - Titanium machining tips
I have learned over the years that titanium machines exactly like aluminum but at 10% of the speed and feed. But what do I know, I've only been machining since I was 15 years old. I'm 71 now.
I was previously under the mistaken impression titanium was relatively easy'ish to machine, so the article was very interesting!
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
HSS does fine, BUT, your feed rates are so slow with it that you could probably take a vacation and come back when the part is finished. Cobalt drills and roughing end mills perform OK,but for any kind of speed you will want 4 or more flute carbide tooling. Preferably coated.
When I was working at Douglas I had to drill titanium parts. Our method was cobalt drills, low rpm and heavy pressure. Worked okay, but we all hated working with Ti.
