Good video. If I might add (you neglected to mention it in your pro/con part of the vid), the biggest pro of flood coolant is that it is more effective at cooling the work than a mist system is. You have far more mass (and water has a better Cp than air / oil) translating the work removing heat generated by the cutter.
