587,495 active members*
3,146 visitors online*
Results 1 to 5 of 5
    Sep 2012
    55
    How to set origin on Ruida 6442?
    I bought a Lightobject R5 controller (relabeled Ruida 6442) and have it working finally- as it happens you can only use the LO version of RDworks. I have contact with the program
    and read and rewrote the vender settings from the card and have pretty good function... except it tries to drive into the left upper corner of the bed and the limit switches are on the
    right upper corner. Does anyone know how to reset it? Thanks Gene
    Jun 2014
    611
    Re: How to set origin on Ruida 6442?
    Hi, I don't understand what's LO version of RDworks..can you please explain it?
    you mean the laser head start to work at left upper corner?
    do you see "origin" button on the panel? you can set the origin position where you like.
    if this function doesn't work, I think you change setting of your software.
    position is "current position"? (I want to upload a picture, but it false)
    and check config-system setting-"tick" axis y mirror, laser head is upper left.
    - - - Updated - - -
    Sep 2012
    55
    Thanks for the reply Nolan. The LO version is an edited version of RDworks that works with their Ruida control card. I have worked out most of my problems. Thanks again. Gene
    Jun 2014
    611
    good~:banana:
    Nov 2016
    2
    look on the control display on the machine, there is a menu for that there
  1. Information about RuiDa RDC6442G
    By Labmaster in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2020, 06:56 PM
  2. What is the difference between a Ruida RDC6332G and RDC6442G controller?
    By AdrianPage in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-07-2018, 05:42 PM
  3. Ruida RDC6442G problem
    By sanyyos in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2017, 08:01 AM
  4. Need some info from Ruida 320 users please
    By GeneMpls in forum Laser Hardware
    Last Post: 03-20-2016, 08:54 PM
  5. Which controller to go for: Leetro 6585, Ruida, AWC708C lite?
    By mrveenie in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2015, 10:45 AM
