Originally Posted by
CNCinCal
Booted up my Kitamura MC1 with 0MB control and it homed perfectly, but would not respond to any commands. Checked out control cabinet and found spindle servo had this alarm. I did quite a bit of searching and couldn't find another thread with the same alarm. According to the maintenance manual, AL-16 to AL-23 = Defective arithmetic circuit and peripheral circuit. The control had a low battery alarm, but did not lose the parameters. I have since replaced the batteries under power.
If I remove the board, will I lose the spindle parameters in the unit?
Part of the trouble shooting in the manual requires I check voltages on the board. Those test pins are obstructed by the orientation board. Can I remove the orientation board and power up the control without harming the unit?
If I need to replace the unit, how hard is it to access the parameters and record them, without screwing them up? Are they protected?
Any tips as to how I should proceed?
Thank you in advance.
Roger
