587,143 active members*
3,482 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Need tooling advice on pocket milling 316 Stainless
Results 1 to 4 of 4
    Oct 2009
    254
    Hey guys,
    I need some advice on best recommended tooling for pocketing out 316 SS. Pockets would be about 1.2" dia x .400" deep. I was thinking some of these coolant thru indexable end mills. Let me know if they would work great. I can get in 5/8, 3/4 & 1". I was think either the 5/8 or 3/4".
    SHARS 3/4" Coolant Thru Indexable End Mill Cutter APKT APMT 1003 NEW
    Thanks for the help.
    Oct 2012
    342
    Re: Need tooling advice on pocket milling 316 Stainless
    SGS Z Carb Variable Helix
    SGS36517 would work or
    SGS36866
    A little better but harder to find are IMCO M924 series variable helix end mills.
    1/2" square corner 1" LOC - #67213
    1/2" 0.015R 1" LOC - #67214
    1/2" 0.030R 1" LOC - #67214
    Finish pass with a IMCO M905 5 flute.
    Follow the manufacturers speeds and feeds charts for these end mills and you will be removing stainless at a surprising rate.
    -Dan
    Oct 2009
    254
    Hi Dan,
    Thanks for taking the time to write that out. I will look up each of those part numbers and go from there. Appreciate your time.
    Have a nice day.
    Take a look at gorilla mill . their variable flute mills are really good for tough materials , their Sasquatch series is absolutely wicked . Gorillas carbides are the hardest carbides that I've come across to date and it's really evident while grinding a flat . A few years back I set up a gear shop with them when they couldn't find mills that could stand up the the heat treats that they were milling , They were taking brutal sized cuts and were slotting 1" diameter 1.625 deep(open at the bottom) , the sasquatch purred thru it . . Their original tool life was 2-4 parts before the tool would snap , the sasquatch bumped it to 18-20 at double the feed rate before they'd pull the tool out to send for regrind . They aren't cheaply priced but the cost saving is in the longevity
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  1. Pocket in stainless
    By orion_134 in forum MetalWork Discussion
    Last Post: 11-27-2013, 07:04 PM
  2. Help with a deep pocket in stainless.
    By rustyolddo in forum MetalWork Discussion
    Last Post: 10-17-2010, 01:21 AM
  3. Advice Milling 400 series stainless
    By andenbrendrew in forum MetalWork Discussion
    Last Post: 12-23-2009, 06:51 AM
