Re: Need tooling advice on pocket milling 316 Stainless
Take a look at gorilla mill . their variable flute mills are really good for tough materials , their Sasquatch series is absolutely wicked . Gorillas carbides are the hardest carbides that I've come across to date and it's really evident while grinding a flat . A few years back I set up a gear shop with them when they couldn't find mills that could stand up the the heat treats that they were milling , They were taking brutal sized cuts and were slotting 1" diameter 1.625 deep(open at the bottom) , the sasquatch purred thru it . . Their original tool life was 2-4 parts before the tool would snap , the sasquatch bumped it to 18-20 at double the feed rate before they'd pull the tool out to send for regrind . They aren't cheaply priced but the cost saving is in the longevity
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
