587,659 active members*
3,289 visitors online*
Page 5 of 5 345
Results 81 to 90 of 90
  1. #81
    Sep 2010
    717
    Re: My new machine desing, "CNM13"
    Made & installed a couple of dust/safety/sound reducing covers:
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
  2. #82
    Sep 2010
    717
    Started on the 4th axis hoping to finish it some day.... Drilled & tapped some holes on the servo mount as the old servo had different dimensions. Made a 12mm steel shaft to attach btw. the servo/gear box.
  3. #83
    Sep 2010
    717
    Got the A axis servo installed to the cyclo gear box. Did some testing and I noticed the servo runs/creeps SLOW when it should hold position.
    It's an (early model) DMM 900W Dyn2-H drive & DMM 400W servo. I have connected the cables that came with them. The I/O cable is a plain 9 pin "null modem" cable, fairly long too, so I'm guessing it picks up noise...?
    Any ideas before I replace the wiring to shielded+twisted pairs?
  4. #84
    Sep 2010
    717
    After some troubleshooting, I got the servo drive working
    - The problem was between the LPT Port & servo drive. It has twisted pair wiring but still the drive got extra input "ghost pulses". Very sensitive I guess..
    - I changed in Mach3 the Step pulse to active low, and now it works as it should. The step signal is now +5V "at rest", and drops briefly to 0V at a pulse.
  5. #85
    Sep 2010
    717
    Did some more testing with the servo, seems to work fine...
    Also made a few parts for the A axis. Very happy with how rigid the machine is at the moment. Just in case, will still make some extra braces etc.. Won't hurt, even if it's fine as is.
  6. #86
    Sep 2010
    717
    Almost finished with the 4th axis.. Hadn't noticed before, but the cycloid gear box output shat has a little slack... Not much, but I can feel it. I guess it's worn...
    Now I'm not sure if it's usable. Can't afford a new gear box at the moment.. Any DIY ideas?
  7. #87
    Sep 2010
    717
    A pic of the 4th (A):
    Attachment 284558
    Not in it's final position and not adjusted straight. Did some testing with wood, worked almost ok even though it has some slack.
    Works fine when tool is stationary & A is rotating. Won't be able to do any precision parts with it though.
  8. #88
    Sep 2010
    717
    I'll leave it at his. Most things are done
    A few minor problems etc still to solve but let's call this "finished": :cheers:
  9. #89
    Apr 2009
    5516
    Quote Originally Posted by hub View Post
    It's never ever done! Home made CNC's are like boats! You're always tinkering with it... and spending money....
  10. #90
    Sep 2010
    717
    Quote Originally Posted by louieatienza View Post
    You're right Let's call THIS model finished. (Some parts are already marked CNM15, which is the next design I'm working on....)
    I'll take a break building the machine and actually use it for a while
Page 5 of 5 345
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
  4. First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000
    By buschhoff in forum Want To Buy...Need help!
    Last Post: 03-21-2010, 12:37 AM
  5. Need CNC machine to cut .01" 302 full hard SS sheets (6" x 20")
    By Lowe in forum Want To Buy...Need help!
    Last Post: 03-23-2009, 06:58 PM
