587,481 active members*
3,166 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Journeyman 330 Info
Results 1 to 17 of 17
    Mar 2015
    15
    Journeyman 330 Info
    So my partner and I picked up a Journeyman 330 yesterday with the dynapath Delta20 Controller and Fanuc Spindle drive.
    It is missing the y axis gear reduction and servo motor.
    So far everything else seems to work and we where able to reference the machine and get the spindle started.
    I have searched google and just can not seem to find very much info on the 330's If anyone has any pics of what the gear reduction looks like on the y axis that would be awesome,trying to figure out what all is missing and track down the parts.
    Attachment 272348Attachment 272350Attachment 272352Attachment 272354Attachment 272356Click image for larger version.
    Aug 2012
    44
    Re: Journeyman 330 Info
    Hi- Nice find! I have a J320 and it looks real similar to your 330. A LOTof the parts look identical. I'll get some pics of the Y drive sprocket setup, and other parts and send the link to you. Hopfully this will at least help a little bit.
    Aug 2012
    44
    Do you have the Y drive housing (motor mounts to the back side)?
    Mar 2015
    15
    Quote Originally Posted by fahrphrompuken View Post
    I do not have any of it. Thanks for the help. Thinking we may have to figure out the reduction and make one ourselves.
    Aug 2012
    44
    It's really just a housing, and two pulleys with a cogged belt (just like the X). Here is a link to the gallery :
    Message - My Photo Gallery
    I'll dig up pics of just the housing assy.
    The opposite end of the Y screw has a shaft that was used to mount an encoder, if the servo motors were upgraded, they probably used motors with encoders mounted on the motors.
    You can use the same size pulleys as the X drive, I think the ratio is the same for both.
    BC
    Mar 2015
    15
    BC
    Thank you so much. i opened up the x axis looks like all i need is a motor asome pulleys and a belt to get this working. My servo looks like a baldor but thats all i can tell the tag is all worn out. I think i found a motor on ebay but not sure yet.
    Aug 2012
    44
    This is the standard servomotor that Autocon included in the Delta MCP upgrade package. It is the same motor for all three axis. These are the ones on my J320. I have seen a few of them on ebay for pretty reasonable prices lately.
    Attachment 272368
    Feb 2009
    6028
    Just make sure you get one marked special. Those had different encoder pin outs if I remember correctly.
    Mar 2015
    15
    Quote Originally Posted by underthetire View Post
    Good to know thank you. I wish I could read the label on my motor..
    Mar 2015
    15
    heres what I came up with off the z Axis motor
    Baldor 4201989
    150VDC
    current 13c 55 peak
    mfg code 4190 68964
    Tach 7
    Encoder 1000l
    Do the rpms of the replacement motor need to match or can we find one with same encoder and tach?
    Also I did not see special marked any where.
    Aug 2012
    44
    The encoder needs to be 1000ppr and the tach needs to be 7v/1k rpm. Are you using the ServoDynamics 1500 series servo amps? Those are what most of the MCP packages used to replace the original Gould pwm amps.
    You could use other resolution encoders, but would have to do a lot of calculating, and have to enter the parameter programming in the Delta20. The SD servo amps are designed for use with a 7v /1k rpm tach signal.
    If you do not find a motor specifically stating "special" in the model name, but the rest of the specs are good, and it has the same 16 pin connector, you would be able to use it.It might require a little re-wiring of the connector, but nothing too bad. I can send you the Dynapath wiring diagrams if you need them.
    Mar 2015
    15
    So so long as tach and encoder match the motor rpm is not hugely important.
    Wiring diagrams would be great. Send them to [email protected].
    I will check boards later on today to see what they are.
    Aug 2012
    44
    Correct. I think any MTE-4090 will have all the correct specs, just as long as the encoder, the tach voltage, and the connector is correct.
    Also, if you look on the Dynapath chassis/card cage, there should be a foil sticker with "Autocon" across the top that should show the model (prob. something like 'Delta 20 MCP") and a serial #. That will help determine the correct set of prints. If you do have the SD servo amps, I have a manual I can copy and send you too, with diagrams, and adj./tuning info.
    Mar 2015
    15
    Here is the info on the dynatron box
    P/N 4200851
    S/N 707456
    Attachment 272838
    Aug 2012
    44
    I think that's the power supply sticker, so your close. The sticker should be on the unit that looks like this (on the left)...
    Attachment 272850
    The sticker should look like this.....
    Attachment 272852
    Mar 2015
    15
Name:	2015-03-18 18_29_59-IMG_20150318_182848 - Windows Photo Viewer.png
Name:	2015-03-18 18_25_48-IMG_20150318_182317 - Windows Photo Viewer.jpg
    Mar 2015
    15
    Been working on clean up and fixing the rough ball screw on y axis
    Found the bearing block(nut) was a little galled up and all the lil balls fell out on removal.
    Attachment 273116
    Attachment 273118
  1. Looking for Info, Patent #'s, Info on Milling Machine Automatic Tool Changers
    By CNC-Joe in forum Uncategorised MetalWorking Machines
    Last Post: 08-22-2013, 05:41 PM
  2. Journeyman 350 info wanted
    By trafficbikes in forum Tree
    Last Post: 01-26-2011, 05:32 PM
  3. Looking for info: Tree Journeyman 465
    By jcolley in forum Tree
    Last Post: 12-01-2010, 01:02 AM
  4. Journeyman 325 tree
    By ramsey321 in forum Tree
    Last Post: 09-12-2010, 11:05 PM
  5. Info request; Tree Journeyman 200U
    By lumberjack_jeff in forum Tree
    Last Post: 02-21-2010, 04:13 AM
