587,487 active members*
3,724 visitors online*
Results 1 to 3 of 3
    Jan 2008
    74
    motorized Z axis
    Hi all,
    We are currently checking out options for purchasing a CNC lathe. We are considering a bar feeder but hardly have enough space to set it up. Occasionally I'll see something like this advertised:
    Standard Bar Capacity: Z axis: (motorized) 2.8". What exactly does this mean, are there lathes out there that will feed the bar in by themselves without having a separate bar feeder?
    Feb 2009
    6028
    Re: motorized Z axis
    Sounds like some kind of bad translation. You can bar pull on any CNC lathe as long as it has a turret and hydraulic/pneumatic chuck. You can also use a sub spindle to pull bar on a twin spindle lathe.
    Jan 2008
    74
    ok, thanks for the reply. We currently do bar-pulling. The main reason I would be wanting to go with bar-feeding is to improve on cycle time. With our current setup we have a Royal bar puller in the turret, and after each part, I have to index to the puller and grab the bar and pull it out. Is it reasonable to expect faster cycle times with a bar-feeder than a puller?
  1. Motorized Up/Down table
    By Ken_Shea in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-03-2011, 06:49 AM
  2. Need help with 7" motorized lcd housing
    By thejets in forum Mechanical Calculations/Engineering Design
    Last Post: 03-08-2010, 12:50 AM
  3. Need help with motorized positioning
    By xshaper in forum Work Fixtures / Hold-Down Solutions
    Last Post: 11-26-2007, 12:38 AM
  4. Motorized Z Axis - Advice
    By ADucci in forum Linear and Rotary Motion
    Last Post: 07-02-2007, 04:56 PM
  5. Has anyone motorized a slide like this?
    By zephyr9900 in forum Linear and Rotary Motion
    Last Post: 01-26-2007, 07:08 AM
