587,832 active members*
3,466 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM a lost ATC macro Kitamura mycenter0
Results 1 to 16 of 16
    Dec 2009
    14
    Re: Fanuc OM a lost ATC macro Kitamura mycenter0
    I guess it to be Side Mounted Magazine with a Tool Change Arm. Tools are behind a door. one arm picks up one by one and bring it to the spindle.
    The indicator flashes orange when call tool. I do not see the alarm number. the machine stops.
    I have a paper copy of the ladder diagram. It takes a lot of work to get it readable image attached here.
    Would it help?
    It is possible that I have broken something when I changed the data transmission ic.
    Sep 2010
    1230
    Quote Originally Posted by Hexa65 View Post
    Would it help?
    Take a picture of the Tool Change Mechanism and Post it here. If its the same as the earlier MyCenter I worked on recently. I can point you in the right direction.
    Regards,
    Bill
    Dec 2009
    14
    Some pictures.
    Sep 2010
    1230
    Some pictures.
    For further help, take a look at parameters 0230 through to 0242 inclusive for the number "6" being registered. If so, Post the parameter number here. Also, look to see if bit 5 (6th from the right) of parameter 0040 is set to "1", and Post the answer here.
    Regards,
    Bill
  1. Fanuc OM, lost tool change macro
    By laka in forum Fanuc
    Last Post: 06-08-2022, 09:11 PM
  2. Replies: 0
    Last Post: 04-19-2011, 02:05 AM
  3. Replies: 0
    Last Post: 04-14-2011, 04:24 AM
  4. Kitamura Mycenter1/485 Parameters lost
    By huub in forum Kitamura
    Last Post: 12-24-2010, 10:18 AM
  5. Replies: 1
    Last Post: 12-24-2010, 06:00 AM
