Mod III was drilling pulley side drain at same height as chuck side drain which is center of lowest roller and right where Timkin recommends a drain to stop surging/friction/heat build up. Don't worry the stock bearing will overflow into the headstock if you overfill it.
Attachment 235968Attachment 235970Attachment 235972![]()
Mod four is a heavy gauge but flexible plastic notebook cover I made two splash guards or dams to keep oil out of the headstock. I'll rough them up and inside the headstock and epoxy in place. Plenty of room to pass the journals through when my spindle arrives.
I've been thinking about a permanent tube from one side to the other to totally isolate the spindle and it's oil which would be a much better solution.
Attachment 235978
I know I don't know your situation but I'm on my third replacement spindle. The first was cosmetically rough on the corners and the threads were buggered but also fixable but I could have cleaned all that up. What I couldn't fix was the undersize journal.
The second spindle was perfect! Except the holes for the camlocks were .040" too small.
The third looked like a used spindle and just not acceptable, so if this next one is bad things don't look good for me. That's why I said if your replacement spindle has good measurements on the journals, no damage to the spindle nose especially the camlock taper then I would hang on to it like a life raft.
Mikbul
Hi All:
This forum is huge. I wasn't sure the best place to post this. Hopefully I can get the answers I need here.
I am looking at buying a Southbend SB1001 8K lathe because - based on all my reading here- this is a higher quality lathe for the small Chinese made lathes. My intentions are to Convert it to CNC. I have run into a few issues though.
1). I hear the 8K might be discontinued and parts may be hard to get. Can anyone confirm that?
2). I don't see anyone that has converted this lathe to CNC
3). I can't seem to fin any 8X conversion kits around. Does anyone do this....anywhere.?
If the SB1001 8K is not a good candidate, than does anyone have advice for one that is? I am limited on space, so the 8K is about as large as I can fit.
Thanks.
Mike Norman
G-Force Racing Development
www.mngforce.com
Are you following me around? Guess I'm not the only one working on acquiring new skill sets.
Everyone here treat Mike very nicely. He's a super sharp guy with lots of good ideas and tons of engineering experience.
Mike you'll be unhappy to know the VFR got pretty heavily taco'd at VIR last year. Folded up a perfectly good magnesium rear and generally beat up and broke just about everything else.
So what ya workin on? Something good?
She's not this pretty anymore....
Wow, hey Kenny! I think it is YOU following ME ;-)
What have I been up to? That all depends on when the last time I talked to you was. I left Kawasaki in 2011 to work for Elrod. Got Laid Off for a year. Then, just took a job as the Quality Manager at Honda Performance Development, the IndyCar Race Engine division of Honda here in California. We design, manufacture, test, develop and race the IRL engine and Le Mans/Daytona Prototype cars out of our facility. I now live 300 miles from the Main G-Force, but am continuing the development of the V-4s from my home in Southern CA. I am also developing something very exciting for the NC chassis.....but that's a secret for now
The machining equipment I am looking for now is to set-up my garage to prototype parts for these projects. I am hoping for the lathe like I described here, as well as a G0704 CNC mill (maybe through Midewest Machine Works).
I am so, so sorry to hear about the Taco'd bike. Let me know if there are any parts I can help you with - including frames. And, thanks for the props to the forum. Definitely appreciated.
Mike Norman
www.mngforce.com
Mikbul, thank you. I tried to look up the thread you mentioned above, but couldn't find it. Can you supply a link?
Thanks.
Mike Norman
www.mngforce.com
The SB1001 serial # and manufacture date are on the front top of the pulley cover door above all the threading and pulley speed decals on the lathe ID decal.
I've taken my time and shared my spindle mods and am disappointed that six owners won't give me the time of day to complete the 8K WTF is going on with the spindles project list. Now I remember why I bailed on this site.
On the Tormach OXA tool post, did you have to do any modification to the lathe to install it on the lathe? The guy at Little Machine Shop said that I might have to modify somehing to get it to mount on the lathe. And Grizzly told me I'm out of luck trying to get one to work with the South Bend 8K.
Since no one answer back I took a gamble and ordered the Tormach OXA tool from the Little Machine Shop (3112 Quick Change Tool Post Set, Tormach 0XA - http://littlemachineshop.com/product...ory=-419988835). It was a direct drop in, took all of 2 minutes to install.
This thread is a treasure trove of information. I also want to take a drive to the PA Grizzly store and browse the lathes. Its kind of a toss up between the 8K, and the G9972
I am going to order the lathe within the next 24 hours this thread certainly was the deciding factor as I am looking for the biggest bang for the buck .
Thanks guys awesome input
