587,852 active members*
3,881 visitors online*
Results 1 to 7 of 7
    Sep 2010
    30
    Machine Control Operation, no gcode output
    I've been trying to set up machine control operation to run a bar puller on a lathe. Everything seems to be set up correctly including Machine ID file but for some reason when generating gcode for this operation only the start and end of file/job comes out as if machine control operation is suppressed.
    Is there an option or postprocessor/preprocessor feature that I'm missing?
    The only thing I could find is that in the postprocessor the start of job under job_type can be "machine control operation".
    I do see toolpath lines when setting up movements under machine control operation but it looks like the operation is not being passed to post processor. When I run simulation I don't see any tool movement however and on the tree the preview box is permanently checked and grayed out, see picture.
    Attachment 227332
    Any input is greatly appreciated.
    Dec 2013
    47
    Im trying to edit my post processor . Ive had the same problems for different views in 4th axis. Its because one of the files .prp .gpp are not configured correctly for your controller.
    Oct 2007
    499
    I think it would be a good idea to post out a program that uses the MCO function with 'trace' set to 'all' and see what variables the CAM is passing to the post. Then you can build something into your post using those variables to get the code output you desire.
    Feb 2011
    252
    Re: Machine Control Operation, no gcode output
    hi,
    Send prz.file on [email protected]
    Mar 2011
    79
    the reason you cant check to see it on the screen is because there isn't any tool movement. or better put is no tool path no preview. if you want to see movement you will need to run the machine simulation.
    Jul 2014
    222
    ive got the same problem, I'm trying to program A and C axis rotation in machine control operations window but when I play simulation nothing happens, also in g code there is no command at all, except start and end of program.
    Feb 2019
    1
    Hello. How I can turn on or include "machine Control Operation" in post (Solidcam)?
  1. Best place to learn V26 to Gcode output?
    By originator in forum BobCad-Cam
    Last Post: 02-20-2014, 04:54 PM
  2. Need Help Understanding Sheetcam Gcode Output
    By Beefy in forum Waterjet General Topics
    Last Post: 09-18-2010, 06:35 PM
  3. Solidcam output weird Gcode
    By kn6398 in forum Solidworks
    Last Post: 03-19-2009, 01:55 AM
  4. gcode problem with drilling operation
    By psehorne in forum G-Code Programing
    Last Post: 02-23-2009, 05:43 PM
  5. does deskam only output metric gcode?
    By july_favre in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-23-2004, 09:44 PM
