587,493 active members*
3,514 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Tapping with Torus Pro and Reversable Tapping Head
Page 1 of 2 12
Results 1 to 20 of 27
    Jul 2007
    675
    Saw a lot of questions about tapping with the Torus Pro, so I produced some footage. Let me know if you have any questions. Made tapping so much easier in a production enviorment.
    Spindle Speed: 300IPM
    Feed In: Calculated - 5%
    Feed Out: Calculated * 2
    Link to Self Reversing Tapping Head
    0 1 4" Tapping Tap Head Self Reverse Drilling Milling | eBay
    Link to Tap Used
    Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
    Jun 2008
    1082
    Thanks for recording and posting so many videos! I got myself a tapping head as well, but I haven't got myself out to the garage to try it out yet. Once I do (assuming it works) I'll record a video. Do you mind if I post it in this thread as well?
    Feb 2006
    7063
    Kelvin,
    FYI - I made a simple mod to my mill and the tapping head. I fastened a piece of 1" x 1" aluminum up between the webs on the bottom of the head, a few inches behind the spindle. I put a 1/2" diameter vertical hole in the middle of it. I then removed the torque arm and its mounting plat from the tapping head, and made a new, longer plate, and attached a piece of 1/2" rod to it vertically. I can now insert the tapping head into the spindle, and the 1/2" rod extends up into the hole in the hole in the aluminum block, to secure the torque arm. I can now tap without having to hold onto the arm.
    I'll try to remember to take a few pictures next time I go out to the shop.
    Regards,
    Ray L.
    Jul 2007
    675
    Quote Originally Posted by Hirudin View Post
    Go for it!
    Sent from my SCH-I605 using Tapatalk
    Jul 2007
    675
    Quote Originally Posted by SCzEngrgGroup View Post
    Kelvin,
    Regards,
    Ray L.
    I think I get the idea. A pic would be awesome thanks
    Feb 2006
    7063
    Pix:
    Regards,
    Ray L.
    Mar 2011
    480
    Great info guys. I've been contemplating a tapping head as opposed to the cost of $$ thread mills. Thanks for posting.
    Jun 2008
    1082
    Oops, double post. My intended post is below...
    Jun 2008
    1082
    I finally tried out my tapping head. It's pretty great!
    I recorded a lil' video of it in action and am currently uploading it...
    http://http://www.youtube.com/watch?v=VGhm96ntPAY
    Jun 2004
    6618
    Nice! That is a lot of tapping for sure. I can see it was well worth it for you to find a nice solution. Have you tried using just coolant? We get away with it on the Torus.
    I use different types of taps though. Mine actually push the material out the bottom. Of course they are all through holes. Would not work too well in a blind hole.
    Lee
    Jun 2008
    1082
    I had done one set of holes like this before recording this video and I let a bunch of them go with just my Fogbuster going. I'm assuming the Fogbuster didn't help at all except for pushing the some of the strings away. It honestly seemed to work fine but I didn't want to let it go for very long.
    Feb 2006
    7063
    I've found lubrication - i.e. oil not coolant - is a BIT help when tapping, especially on smaller sizes.
    I'm curious how deep you guys manage to go in 6061, and what thread % you're aiming for. In most cases, I use a 70% tap drill, but I think in the future I'm going to go to 60%, or perhaps even less, to make lifer easier for the tap. I find 3/4" depth works OK for 1/4", 1/2" for #6-#10. Any deeper, and I risk tap breakage.
    What seems to me the biggest limitation is the VERY abrupt reversal when the head is retracted, and the fact that there is no predictable, repeatable way to set the clutch, to limit torque on the tap. I'm surprised they don't use a more "gentle" clutch to engage the reverse gears.
    Regards,
    Ray L.
    Jun 2008
    1082
    Those holes are the only ones I've done and they were 8.5 mm deep.
    I don't know what "thread %" means. :/ I did a quick search and it looks like it refers to the size of the pre-drilled hole. For these holes I just used the closest drill I had to the recommended 4.2 mm drill size (a #19 bit, which is less than a thousandth larger). That reminds me: I was intending to put that info in the YouTube video description.
    One of the nice things (or maybe handicaps?) of Procunier tapping heads like this one is that I do not believe there is a clutch adjustment. This one is suppose to be able to go from #0 through 1/4".
    Jun 2004
    6618
    Percent of thread is just like it sounds. Percent of possible thread profile.
    I am not even sure you could use 100% threads on both the fastener and the hole. I think that might be called "Welding".
    It would certainly make for a lot of friction. Unnecessarily.I get away with 50 to 55% threads most of the time. I like more thread in my aluminum parts though. 75%.
    Here is a chart that I like to use.
    Supplies
    It works great for rigid tapping and coolant and also works well for all my parts.
    That is one nice thing about rigid tapping that isn't that obvious. There is not jerking. Smooth in, smooth out. Nice.
    Lee
    Mar 2009
    388
    Quote Originally Posted by LeeWay View Post
    Supplies
    Lee,
    I'm interested in the 75% you use on aluminum. Are you using 75% with one of these tapping heads?
    Here's why I ask. I have one of these tapping heads, and haven't used it yet. The reason why is yesterday I hand tapped about 10 or so holes for a #10x32 fastener. I used a #21 drill, which according to your chart is 75%. Like always, I had to reverse direction every 1/4 - 1/2 turn to free the material or I would have broken the tap. Looking at these videos using tapping heads, it only reverses when it is finished with the hole. How is it that with a tapping head you can get by without reversing direction during the tap, but with hand tapping you cant?
    Scott...
    Instructional Videos for CNC Guitar Building
    http://www.rmgvideos.com
    Feb 2006
    7063
    Scott,
    What kind of tap are you using? For hand or machine tapping, Spiral points are light-years better than standard plug taps. For machine tapping, at least on aluminum, I think form taps are hard to beat. Spiral flute taps are supposed to be really good for machine tapping, but my few experiences with them have not been good.
    At 75% thread, I think you'd be pretty limited on tapping depth. On #10-24, I find it difficult to go more than about 1/2" without risking occassional breakage.
    Regards,
    Ray L.
    Jul 2006
    525
    Quote Originally Posted by sagreen View Post
    Lee,
    Scott...
    Lee has a torus, so he can rigid tap; doesn't need a tap holder.
    Machine tapping provides higher surface speed, consistent power transmission, no axial misalignment, and no off-axis forces..
    I regularly drive taps damn near as deep as they can go, in a single pass, 75% in aluminum; but have far more confidence when using a form tap
    I should record a video of peck tapping
    Not trying to hijack this thread, but wanted to show y'all what we use in the shop. We are doing tapping as a secondary operation on this tapping arm: http://flexarminc.thomasnet.com/view...pping-machines
    It taps just as fast as the torus pro does and I can change taps in 5 seconds. We have broken just one tap in 5 years of use. Each tap holder has an individual clutch ring on it.
    I am sure we will look at tapping with TC heads on the torus pro eventually, but for now this is a really good option for us.
    Nate
    Fine Line Automation
    www.finelineautomation.com
    Sep 2006
    1738
    Look like an awesome and efficient way to tap.
    Quote Originally Posted by FineLineAuto View Post
    Not trying to hijack this thread, but wanted to show y'all what we use in the shop. We are doing tapping as a secondary operation on this tapping arm: Tapping Machine, Tap Arm, Tapping, Tapping Arm, Tap
    Nate
    Home - Fine Line Automation
    Jun 2004
    6618
    I had considered putting a geared motor on our hand tapper.
    Mine is from Enco, but they went crazy on the price. The Grizzly is virtually the same tapper.
    Grizzly.com
    It works very well, but of course, will wear on you if you have a lot of holes.
    That auto arm tapper looks very cool though. I looked at those a while back and was tempted to check the pricing on them, but never followed up. Kinda glad I didn't now with the Torus.
    Lee
Page 1 of 2 12
  1. Reversing Tapping head vs Tension/Compression tapping Head
    By apeman88 in forum Tormach Personal CNC Mill
    Last Post: 01-25-2011, 03:39 PM
  2. Tapping with the Tormach Tapping Head
    By bobs_charger in forum Tormach Personal CNC Mill
    Last Post: 04-24-2009, 10:08 PM
  3. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  4. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
