Im happy to hear they dont want to discontinue it, they must have sold a lot of them at this sale price. Im really hoping they keep developing it. Put a QCGB on it and it could stand up against the other small lathes. Of course then grizzly could justify charging a little more, and some wouldnt mind paying. It was a wise decision to buy South Bend.
Did the manual impress anyone else? Clear exploded views and parts lists, although the metal work 101 section wasn't exactly necessary. I dont know how many people would buy it as a first lathe.
I've tracked the spindle bearings down. Little confusing because they say its a 30205 Nachi Tapered roller bearing, but the 30205 bearing has a 25mm ID. The SB1001 spindle bore of 28mm. So it would either be a 30207 with 35mm ID or 30208 with 40mm. I hope its the '08 for my spindles sake, I might not get time out in the garage again until the weekend but I will try to measure the spindle bearing journals. Funny they want us to keep it under 2300RPM, VXB says they are rated to 6700RPM with oil.
30208 Nachi Tapered Roller Bearing Japan 40x80x18 Taper Bearings:Nachi-Bearings
I would appreciate the lead on lubricants, and im sure any other lurkers reading would like it to.
