587,739 active members*
3,234 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > VM1 Error msg - OVERLOAD FAULT
Results 1 to 7 of 7
    Mar 2013
    Hello everyone. I have a problem with my VM1. Today, all of the sudden , as a program was running perfectly normal, it interrupted, by an error msg : "OVERLOAD FAULT - RESET OVERLOAD FAULT "
    There is no way i can reset this thing. All relays atm are working. Any idea or someone that had same problem can help?
    thank you in advance.
    Forgot to mention, cant run ANY program, if this fault is nor clear/reset.
    Jun 2008
    1104
    Check in the two white boxes under the cabinet. it'll be either the coolant or the auger tripped in one of the boxes. press the blue button to reset.
    Mar 2013
    Quote Originally Posted by bloke View Post
    White boxes on the back of the machine?
    Mar 2013
    Two white boxes? On the back side of the machine?
    Jun 2008
    1104
    Yes. Just under the electrical cabinet. About 200mm tall, 150mm wide and 150mm deep. Four screws holding the cover on.
    Mar 2013
    ill try that 1st thing in the morning, ty in advance. ill let you know with the results
    Mar 2013
    Good morning, and thank you bloke. Saved the day, was the coolant relay. something passed through the filters of the cabin to the coolant tank, and gave the coolant pump a hard time. Thnx again, keep it up :wee:
  1. Hurco VMX24 ATC Overload Fault
    By Doug E. Hurco in forum HURCO
    Last Post: 12-27-2011, 08:32 PM
  2. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
  3. Help....spindle overload fault message
    By icedog in forum Dynapath
    Last Post: 10-12-2009, 04:45 PM
  4. C Axis Fault Motor Overload Error #27
    By wdwrd68 in forum Fadal
    Last Post: 10-11-2009, 12:07 AM
  5. Drive Fault / Spindle overload
    By DF-ENTERPRISES in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2009, 01:48 AM
