Hello,
I am new to MasterCAM. Can you set it so will automatically know where each surface is and not violate/ crash into the surfaces, even if I didn't select them, set any bounds or set check faces?
Thanks in Advance,
Hades
Hello,
Thanks in Advance,
Hades
You have to tell Mastercam that the surfaces are there.
Select them as check surfaces. Or use a sketch as an avoid area.
John
using check surfaces is one way to have mastercam avoid hitting surfaces you don't want to hit.
you can with a 3d highspeed toolpath then create a containment
like nw Phil said 3d highspeed toolpaths can do that. you can create a boundry and select the model and mastercam will cut everything in that boundry. if you want it to stay away from some of the surfaces you have to make check surfaces or offset the surfaces. I don't recommend you offsetting surfaces but if you had to you can. hope this helps.
All surface paths can use a tool boundary well 95% of them can. this will contain the tool in an area that you create the tool boundary from.
ANd Like John said you can also still use a check surface and define how close it can come to that surface.
Cadcam
Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
Cadcam
I was also wondering if he meant boundry also.
