Hello;
A friend of mine has a Fanuc OT / CNC lathe Whacheon Model ECO-2 and lost the parameters due to a bad battery. We managed to get it working except for the Tool change turret which works manually but doesn't work (the turret keeps on rotating ) from a T code. We suspect it is a parameter problem because it was working fine before the battery problem.
Your help will be sincerely appreciated.
Best regards,
kreutz
