587,913 active members*
3,816 visitors online*
Page 2 of 2 12
Results 21 to 38 of 38
  1. #21
    Apr 2004
    31
    Hi, I think you have your port address wrong; Set to 0x378. Thats a zero, not letter O, for Mach to work. Just a thought.
  2. #22
    Jun 2012
    32
    Thanks for the tip. I tried that and still no motor function. I have a PCI slot parallel card and according to device manager it E400. I tested the parallel cable and get responses when set to E400. I also tested the cable and the pins all go straight through.
  3. #23
    When you turn on power to the driver does the stepper lock up?
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  4. #24
    Jun 2012
    32
    Yup. Motors lock up when power is on.
  5. #25
    ok, try unchecking step low active in motor outputs.
    Hoss
  6. #26
    Jun 2012
    32
    Yes, I actually wired a switch that connects 5v to the EN wire that should enable the C10. I've tested it with a volt meter and get 5 volt reading to the EN port when switched on.
    I think I've tried unchecking step low active in motor outputs but, I'll double check when I get home from work.
    Should all the pull up pull down jumpers be played with? I left them alone since I got it, but wondering if there set wrong. The instructions on how/when to use them is unclear.
    Thanks for all your help guys... specially you Hoss!!!!!
  7. #27
    Jun 2011
    695
    Have a look at this guys video series (i think it is 8 videos) it will help you see the wiring. It helped me on my first go around.
    [ame=http://www.youtube.com/watch?v=9tzr-QSPzTM&feature=plcp]cnc electronics - main power supply - YouTube[/ame]
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  8. #28
    Yeah, I linked on my site to Buildyourcnc.coms page that has all the videos together.
    CNC Electronics and Wiring
    Great stuff.
    Hoss
  9. #29
    Jun 2012
    32
    Those videos are nice and I used them originally as guides to wire and trouble-shoot. In the videos he test the volts on the parallel cable and the C10 BOB while jogging the axes. I did the same thing with the same results, so I'm assuming that there must be an issue further down stream in the driver or motor. But, the motors lock up when turned on so it must be the driver? Right?
    Thus, can test the output on the driver with a volt meter somehow?
    Also, I followed this schematic http://www.kelinginc.net/KL-6050WithC10.pdf from keling except where they wire the A axis I wired the X axis? Does that matter?
  10. #30
    Jul 2008
    91
    Where you wire the axis does not matter as long as its wired to output pins and the pins match up in the "ports and pins" menu.
    How are your jumpers on the C10 set? If you followed that diagram then com should be set as 5v, pins 2-9 should be set as output, I don't about the pull up/down jumper.
  11. #31
    Feb 2006
    7063
    "Where you wire the axis does not matter as long as its wired to output pins and the pins match up in the "ports and pins" menu." - Sadly, with many CNC4PC BOBs, that is NOT true. You are much better off using the pins as indicated in the CNC4PC documentation, as the Step signal optos and buffers on their boards are often designed for higher speed operation than the other outputs, and assigning a Step signal to another output may result in unreliable operation. Ask me how I know....
    Regards,
    Ray L.
  12. #32
    Jun 2012
    32
    It runs!!!! It was the jumper pins. Man those are hard to see where they are set. So, for anyone ever doing this I would recommend setting the jumper pins before you even wire it up.
    Thanks HOSS!!!!
  13. #33
    Apr 2012
    38
    Glad to see that you got it working!
    Was it hard to wire that box? How long did you do that? I don't mean the problem, I mean only the wiring time.
  14. #34
    Feb 2012
    296
    If you are thinking about paying someone to build it for you...don't. Take the time to learn how to do it yourself and it will come out much better and you will be able to troubleshoot a lot easier.
    Ask me how I know.
  15. #35
    Apr 2012
    38
    Rock you talking about me?
    If so then I have already planned to go that road.
  16. #36
    Feb 2012
    296
    Yeah, thought you were possibly considering buying a pre-assembled box and I was just chiming in with my first-hand knowledge of the subject.
    I am going to be building my own now as well, those videos above helped a TON!
  17. #37
    Jun 2012
    32
    The wiring was pretty easy due to the schematic that's on keeling site. I wouldn't try stuffing into dell pc tower though, its a tight fit and working on it is a pain.
    Also, I don't think I learned a lot building the box. In the time it took me to troubleshoot and build a mediocre box I could of just worked at my job and earned an extra $300. I'm not sure it was worth it. I'd rather be learning CAM or MACH3
    I just looked at keling site and you can get a plug and play box for about the cost of all the parts including all the little stuff. Now, I kinda wish I just bought the box and spent the extra time reading about how stepper drivers work.
    A CNC retrofit is a huge time commitment. Learning metal working / machining is too. Hell, building parts is tedious. That being said, choose your battles, sometimes buying is smarter than building.
  18. #38
    Jun 2012
    32
    It took me about 15-25 hours to do everything. From stripping everything out of an old pc tower, layout, and wiring. If you include troubleshooting and that I'll probably re build the whole thing... 50 hours. The hair-loss, insomnia, and Hoss's generous time... priceless.
Page 2 of 2 12
  1. $2000 Budget for Milling Machine and CNC Conversion
    By zagitazz in forum Benchtop Machines
    Last Post: 06-26-2012, 11:34 PM
  2. What VMC with a budget of 40k?
    By andrewkeisler in forum Uncategorised MetalWorking Machines
    Last Post: 09-29-2011, 12:34 AM
  3. CNC Budget
    By Sawcnc in forum Joes CNC Model 2006
    Last Post: 02-07-2011, 06:48 PM
  4. 50k budget. To buy, or not to buy ?
    By Need CNC in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2009, 12:51 AM
  5. SIEG X3 Budget DIY CNC Conversion Ongoing Project Summary
    By Ninhil in forum X3/SX3/G0619/G0463
    Last Post: 03-07-2007, 01:26 AM
