587,790 active members*
3,692 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > $2000 Budget for Milling Machine and CNC Conversion
Page 1 of 3 123
Results 1 to 20 of 45
    May 2012
    0
    I've set aside a total of $2000 bucks for buying a decent Milling machine and for converting it to a CNC. I'm a newbie so I thought that I'd get some help and advice from the pros here. I want to include everything in my budget required to start up (everything adds up) I'm pretty handy, but I have zero experience with machining other than shop class in high school and a class I took up at Rolla. I want to have the ability to machine aluminum, plastic, (maybe even 1/8" steel?) parts for building RC cars/plane/robot without having to outsource or borrow machines. I've got a list of parts and prices that I came up with after researching a bit. I'd appreciate any comments on where I can get better deals or if you suggest a different machine that would be an upgrade but would stay within my budget. Thanks!
    These prices include shipping!
    Harbor Freight Mini Mill $621.93
    Little Machine Shop Mini Mill Starter Kit $105.86
    Little Machine Shop Belt Conversion Kit $150
    Probotix 3-Axis SideStep 180 Stepper Motor Driver Kit with ready to run large enclosure $416.59
    CNC Fusion Mini-Mill CNC kit #2 $597
    Total $1891.38
    Jan 2005
    1943
    In addition to what you have listed, you will need a vise, tooling (end mills, drills, etc.), dial indicator, micrometers, calipers, R8 collets or holders for the tooling. There is an endless list of what you could get, but some of this stuff is pretty much mandatory.
    I think the mill comes with a drill chuck and arbor, but if it doesn't, you will need that too.
    May 2012
    0
    Thanks for the reply 109jb!
    I'm glad you told me that about the tooling and vice, jeez that's obvious!
    I've got calipers and a micrometer. What would I need the dial indicator for?
    My price is inflating as expected. Maybe harbor freight will have one of those 10-20% off deals soon?
    Harbor Freight Mini Mill 621.93
    Tooling Package, R8 Mini Mill Essentials 263.65
    Little Machine Shop Belt Conversion Kit 150
    Probotix Motors and Controls 416.59
    CNC Fusion X2 Conversion Kit 597
    Total 2049.17
    Jan 2005
    1943
    You need at least one dial indicator to tram in the machine. One item I forgot was a precision square. It is clamped to the table with one leg pointing up. Then the dial indicator fixed to the head and the head raised up and down. In one direction this squares up the column to the table side to side. In the other direction it squares it in the fore aft direction. Once the column is square, you then fix the dial indicator to the spindle but out to the side like a flycutter with the probe end of it facing down. you then swing this around on the table to get the spindle square to the table. Most people use a tramming device for squaring the spindle. I'm sure you could find a video on youtube that shows how to tram in one of these type mills.
    Here is a link showing tramming on different machines.
    Tramming a Mill
    You can find lots of x2 related info here including this on tramming.
    http://www.hossmachine.info/Shop_Info.html#tramming
    Hoss
    Oct 2010
    58
    I also see you didn't mention a PC or s/w either. You could grab open source s/w and run on Linux with a low budget PC.
    Yeah, my budget went thru the roof and still is going but hey, it'll be worth it when done. I'm looking to do some 1/4 scale race DIRT cars when I'm done.
    Hang with it and buy as you need.... great forum for LOTS of info here.
    Enjoy, Matt
    May 2012
    0
    Thanks 109jb and Hoss, this is all very useful info! I'll need to refer back to this when I set up the machine and do the tramming. Matt, I have a computer that I built a while back that's sitting around so It'll be perfect to use with this. The probotix kit comes with a free CD with EMC2 CAM software, but it looks like it's only for linux? I have windows 7 installed. I've got a couple CAD programs already installed on my computer too.
    Jun 2010
    178
    EMC2 isn't CAM software it is the Enhanced Machine Controller (comparable to MACH3).
    Also regardless if you go with a windows based controller (MACH3) or Linux based (EMC2) you will need to test your computer for latency. This is a very important issue, and you best start looking into it now because even new computers don't necessarily have great latency and this effects your stepper motor performance.
    Apr 2004
    5752
    If you want to save yourself some headaches, look at the CNC-ready Taig mills. Unlike some of these Chinese machines you're considering, it's ready to attach motors and run. The 2019 CR-ER has travels of 12" X, 4.5" Y, 6" Z and an ER-16 spindle that goes up to 10K rpm. It lists for $1100; I sell it for $1000 within the USA. Get a Gecko 540, put it in an enclosure and add some motors, Mach3 and a dumpster-grade computer, and you've got a working CNC mill capable of cutting plastics, aluminum or steel, well within your budget.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    May 2012
    0
    Lukewarm,
    So does the probotix kit require linux to be on my computer?
    I'm assuming since it lists EMC2 under "CNC Control Software" that means that it does require linux? or can I use Mach 3 with it? I know nothing about the software, sorry.
    3-Axis SideStep 180 Stepper Motor Driver Kit - 3-Axis SideStep 180 Stepper Motor Driver Kit
    Also, maybe I'm getting outside of the topics of this thread, but how to I test for latency?
    Jan 2005
    1943
    EMC comes with a utility to check latency. Not sure about Mach3 since I don't use it.
    May 2012
    0
    awerby,
    Headaches aside, isn't the taig a less capable machine than the x2? I guess that would be my main concern going with a taig.
    Jun 2010
    178
    Zagi Mach3 has a program you run that checks your system to see if it is capable of running it. I don't know exactly how this works as I solely use EMC2 and highly recommend it to anyone even half computer savvy.
    I BELIEVE the EMC disc provided with the Probotix package installs Linux and EMC2 already configured for your stepper drivers. It should be a very painless install. Again keep an open mind, Mach3 is great but EMC is just a lot more robust and configurable. I think the guy who sells these packages is named Len, and I've heard he is very helpful if you have questions about your purchase.
    May 2012
    0
    thanks lukewarm. I just don't want to have to dual boot linux if it's not necessary...guess I'll do a trial install, do the system check thing, and maybe ask len
    Jun 2010
    178
    What about dedicating your one computer to a CNC controller and not dual booting?
    May 2012
    0
    It's actually a really powerful computer, I'd hate to lose windows...however, I honestly haven't used the thing in months. Maybe it's worth thinking about. I guess I could look into CAD programs that run on linux, because I want to use it for that too.
    Having just completed converting an X2 over, I did a short spreadsheet to go back and figure out (roughly) what I spent. I also included links to all of the places I bought each item (Public Document):
    https://docs.google.com/spreadsheet/...lh1YVFqdWVYYmc
    The numbers are all rounded up to whole numbers and I got a hell of a deal on the X2 through Harbor Freight when they were running a special at $399, plus free shipping. The price is back up to the $599 mark now. I did not factor in small items like center finders, cheap dial indicators and other sub $20 items. Based on my numbers, completing the job for $2K is perfectly doable.
    EDIT: The belt drive kit does not have a link because I could not find the site that I bought it at. For reference, it's the kit made by Starleper1 and the kit is phenomenal!
    EDIT (Again): For software, so far I have only purchased Vectric's Cut2D for CAM at $150. I am using the free version of Mach3 since I have no need to go over the 500 line restriction at this time. I am also using the free Desault Systems software Draftsight for CAD. It's simple, but it meets my 2D drawing needs.
    Jason
    RPC Electronics, LLC - www.rpc-electronics.com
    May 2012
    0
    wow, 399.99 plus free shipping is a smokin deal! Maybe I should wait for a while it seems like just looking around the forum that harbor freight runs deals every so often. In the mean time I guess I can just keep informing myself. This has been very helpful, thanks everyone!
    May 2005
    3920
    It isn't that simple, the Taig is a very good mill.
    Quote Originally Posted by zagitazz View Post
    awerby,
    I just got started with this thread and my first concern seems to be that you are jumping into this mill real fast. You mentioned quarter scale RC which to me is a fairly large models and then you express concerns about the Taig. This makes me wonder if you need a capacity greater than X2 class hardware. On the flip side the Taig does have a faster spindle which can be an advantage working the materials you are talking about.
    Let's face it if $2000 is your budget, and you are starting out with very little in your shop you have a tough problem. This is just a suggestion but I'd consider a slightly larger mill and tooling purchases first and then CNC next year. You will easily blow your budget with just tooling, tools and documents.
    So why do I say that, well you will need the following fairly soon after the mill arrives: A milling machine vise, a collet set, tooling in the form of endmills and drill bits, a caliper, micrometer (maybe a set), one of more dial indicators, hand tools of various types, a machinist square, layout and alignment tools, possibly a fly cutter or two, a tool box and other storage, deburring tools (maybe a belt sander) and other goodies. Now some of this can be had cheap even new, but it does add up. On top of that some items really need to be of higher quality. For example don't skimp on dial test indicators and your calipers.
    Now I'm assuming that you have some of these items covered already. Still it is very easy to blow any budget when first getting started. In any event forcing yourself to manually machine parts is a good learning experience for a few months. The obvious problem is that CNC allows you to do some really neat things cheaply. Still getting the feel for machining is an education you can leverage when the CNC function is there.
    The other option would be to just inflate your budget a bit.
    May 2005
    3920
    I expect to see a great deal of pricing pressure on Chinese machines.
    I actually think it is already starting to happen as prices seem to be going up the last two years. So if you find a deal jump on it. That is if you are convinvced an X2 class mill is the right size for you.
    A few books might help. Frankly I've been setting up shop by buying in small chunks over time. It makes the expense less noticeable. Some guys like making a big buy but that isn't me. If you don't already have them the hand tools, such as micrometers, squares and other items can be useful even now, pick them up while trying to figure out which way you want to go.
Page 1 of 3 123
  1. PC Build (~2000$ Budget)
    By c.fehringer in forum Controller & Computer Solutions
    Last Post: 03-23-2022, 02:25 PM
  2. King Rich KRV-2000 Knee Mill CNC Conversion
    By BMSTECH in forum Knee Vertical Mills
    Last Post: 04-23-2020, 03:41 AM
  3. Best CNC Mill for $3000 budget?
    By PhoenixMetal in forum Benchtop Machines
    Last Post: 12-29-2008, 04:57 AM
  4. SIEG X3 Budget DIY CNC Conversion Ongoing Project Summary
    By Ninhil in forum X3/SX3/G0619/G0463
    Last Post: 03-07-2007, 01:26 AM
  5. $6k budget for cnc mill, please help!
    By touser in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2004, 03:14 PM
