Did you have them save it as a PDF file?
Mike
I have the same machine as you and have lost all the commissioning data due to a board shorting out.
Could I trouble you to download A copy of yours and e-mail to me ?
[email protected]
Mark
If I can figure out how to do it I would be glad to help you out.
Mike
Well, I just pulled the dumb azz move of the year.
I am having control issues so I was pulling all of the boards out and cleaning them. I got all done and looked up and said what is this? Before my brain could kick in I had pulled the battery out. So now I have lost the commissioning data. The screen came right up asking for it. Then it went off and now I have nothing.
That is the issue I was having, sometime the control came on and sometimes not. Sometimes it would come on the engage the drives and maybe shut off in a little while.
Now I am really frustrated.
Time to make a call.
Mike
I bought a used input unit, control panel, off of eBay to see if I can get mine up and running. It has all of the boards and "The Battery" is still intact. I'll hook the whole thing up and see what happens.
But, Hardinge came through fast for me and attached is the commissioning Data they sent me. Has instructions and all.
Thank you Hardinge!!!!
Hardinge was always very helpful to me. Glad they are working for you also.
The file you have is for a CHNC2/FANUC 10.
Here is the commisoning data for CHNC1/SIEMENS 810T
Hey, I just made a dumbass move of my own, though I'm not sure it's related; I was setting up tool offsets for the very first time owning this lathe (CHCN-1 w/ Siemens 810T) and decided I didn't want any of the previous owner's % programs in memory, so I did a RANGE DELETE between %100 = %1300, and suddenly the work light went out, and the screen became unresponsive. My only recourse was to restart the control, but it wouldn't turn back on.
Does this sound like anything you've encountered before in relation to having wiped out your commissioning data?
When I turn the control on, the four LEDs light up for only three seconds, then nothing. Usually I hear a bunch of relays clicking, and the beep when it activates, but this time, it's quiet - only the fans turn on. No control display, no characteristic high-pitched whines... just silence.
I also don't see any obvious fault LEDs lit on any of the control boards in the back, but then I haven't actually begun a formal investigation yet.
Torin...
