587,482 active members*
3,246 visitors online*
Page 2 of 4 1234
Results 21 to 40 of 62
  1. #21
    Aug 2010
    278
    Great read on these, very interesting... +1 for that.
    Hive 8 - G0704 CNC Mill - 20 inch Telescope - High Resolution 3D Printer - Lasersaur 100W CO2 Cutter / Engraver
  2. #22
    Jun 2008
    36
    Haven't had much time to put into the machine lately plus its over 105* here in Phoenix so my motivation has been lacking on top of that. Anyways, I purchased plans from Hoss to help speed this process up a bit. Yesterday I started assembling a spreadsheet for all of the components that need ordered. That got me to my first of whats sure to be many crossroads, belt drive or direct drive the 3 axis using steppers. I like the packaging options that a belt drive offers with the drawback of added expense and complexity. From my understanding I would still keep the pulleys 1:1. I would also assume the belts stretch and wear out eventually but are there other drawbacks that I am missing? Most of the builds I see use direct drive so there has to be a obvious reason that I seam to be overlooking. Thanks
  3. #23
    Jun 2008
    36
    Almost a month later and I'm finally happy with the Y axis movement. I ended up just lapping it in until all the tight spots were gone. The surfaces look pretty scary but the movement is smooth and consistent over the whole travel.
    Bottom of the saddle
    Saddle dovetail
    Y gib
    Base dovetail side
    Base gib side
    That's it for today, I had to stop when the garage hit 105*. Next up is the X, a quick check showed that the center of the table is quite loose while the ends are very tight. So there will be some work there as well. Maybe some marking fluid to highlight the high/low points next time too. I have about decided on an electronics setup and will post it up for everyone's review. Thanks for looking...:cheers:
  4. #24
    Jun 2008
    36
    Good from a far but far from good My little 7x is great at making RC sized parts but not so much when you chuck up 3" stock. The pulleys have flaws but I think they will work just need to do the drilling and tapping. They are based of the Hoss plans but with a few little tweaks. Christmas started last week; all new bearings, oversized ballscrew balls, 3x 570oz steppers, 1x 906oz stepper, 3x free upgrade to 8056D, 1x 8070D, connectors and wire. Roton ballscrews and nuts will be here Monday. Still finalizing the rest of the electronics order from cnc4pc and I'll be ordering that around mid week. I have officially blown my budget.:rainfro:
  5. #25
    Pulleys looking good especially for a 7x lathe.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  6. #26
    Aug 2010
    278
    Nice work on the pulleys, since i am going with the HOSS conversation as well i will need to lathe some of these pulleys as well, I don have one so my friend offered me to do it. He has a nice multi axis Mori Seiki.
    If anyone need a pair please let me know, would have no problem to run multiple parts...
    What modifications did you do to yours?
  7. #27
    Aug 2010
    630
    Quote Originally Posted by hive8 View Post
    I might want a pair, Are you doing with or without Quill ? I really want to maintain my quill.
    Thanks, Connor
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  8. #28
    Aug 2010
    278
    I have not decided yet if I should go with or without the Quill, is it good idea to keep the quill on a CNC machine, if there are no problems with leaving the Quill, then no problem in doing so... Also what material?
    Only item i want to add is a ATC since it bought the tormach TTS already, can i keep the quill with that. Also i am doing the threadmill motor conversation, you have your stock motor?
  9. #29
    Aug 2010
    630
    I'm current have just the stock motor. Plan to go to Tormach TTS at some point. Probably manually draw bar mod till I can do a ATC and power draw bar. Not sure what material. I can look on the DVD and see what he listed.
    I don't think there is any issue with keeping the quill, but I'll defer to Hoss's wisdom and experience.
    Thanks, Connor.
  10. #30
    Hive (Anton), you can make a pair of pulleys for connor as he bought a set of plans but you do NOT have permission to profit from my design and make parts from my designs from anyone that asks.
    Hoss
  11. #31
    Dec 2009
    1416
    I've kept my quill and it's useful to me. Power tapping without heads or TC chucks. I also do coordinate drilling sometimes when I don't want to do MDI commands for the drilling. Even if you do a conversion that doesn't use the quill it's all still in there so if you are willing to do the work to keep the quill I can't see it hurting you in any meaningful way.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  12. #32
    Aug 2010
    278
    HOSS i will not profit from making parts this was a gesture to help here... I just ask as a favor since my friend is doing it for me i have to pay for materials, it not the same as connor would come to me and ask to produce the parts, since my friend is doing a run, its easier for my friend to produce multiples as he only needs to set the tools on the lathe once.
    Since conner has the plans and i bought the plans too i hope that it is not a problem... I am posting it here official not over PMs.
    Since i don't have my own lathe its hard for me to make these parts by myself i am pretty sure others are in the same boat.
  13. #33
    Aug 2010
    278
    Quote Originally Posted by photomankc View Post
    I will keep the quill then, makes sense... i like the coordinate drilling idea .
  14. #34
    Like I said, Connor bought the plans so it's not a problem nor is you getting your friend to make them for you since you also did.
    Hoss
  15. #35
    Dec 2010
    Post
    Connor,
    I have no problem making a 1000 sets of parts as long as you pay for them.
    Send me a p.m. with your email address and a drawing if you would like to place a order.
    PDB
    Quote Originally Posted by hoss2006 View Post
    Hoss
  16. #36
    Quote Originally Posted by poordumbasstard View Post
    Connor,
    PDB
    buzz off troll.
  17. #37
    Jun 2008
    36
    Thanks guys. I decided to strip the head down to bare bones, turns out they were the easiest pulleys to make with my current tooling anyway. For starters I'll be running the stock motor with the stock speed control board integrated into the C32/ESS. That's the plan at least.
  18. #38
    Jun 2008
    36
    I'll start by saying that electronics are not my thing which will be pretty obvious with the following questions. So I have been killing myself trying to figure out how I will wire the stock ESC board into the C32. I have identified the role of all wires in/out on the ESC board and have it isolated from the rest of the oem G0704 electronics. When hooked up straight to 120VAC I get CCW motor rotation with the speed adjustable via the pot so no issues there. I would like to automate the F/R switching through the C32 board as well. There are two relays on the C32 that coordinate to two pins through mach. The manual for the C32 says you can control all aspects of the spindle operation RPM, CCW, CW and OFF but does not show the actual wiring. Below is a chart of pin states, relay states and operation states taken from the C32 manual. Using this chart I came up with the below wiring diagram. The only problem I see is that when relays #1 and #2 both go NC I will be shorting the ESC. That is unless mach has already turned the control voltage off. Seems pretty risky to trust in that. My other though is that I need one relay to control a DPDT relay to make the signal switching happen. Also the ESC is rated 0-90VDC 13.5ADC, so I'm not so sure the the relays are up to the task anyways. Any and all feedback will be greatly appreciated.:drowning:
  19. #39
    Aug 2010
    630
    Quote Originally Posted by rob_b View Post
    The relays on the C32 and other Break out boards and speed control boards are LOGIC ONLY and are not intended to handle the load of the motor direct. You have a few options. Option 1, find a speed controller that has provisions for logic forward/brake/reverse built into it. Option 2) Find a relay that can handle the voltage and amps of the motor, keep in mind, you might need to over rate the contacts on the relay because motor start-up is way more than the sustained current on the motor, and you might need a Power Resistor for when you shunt the load for braking. Option 3) Build/Buy a H-Bridge circuit. It's basically a Solid State version of the relay. Options 2 would use the C32 relay for CW/CCW logic switching (probably 12v) Option 3 could use the relay, or be driven direct from the logic pin tied to the relay. Your choice.
    Unless your planning on doing Rigid tapping, no real need to automate reverse.
    Thanks, Connor
  20. #40
    Jun 2008
    36
    Thanks for the info Connor. I want to stick with the stock motor/ESC for now so maybe it would be best to just stick with the stock F/R switch until I upgraded the motor. Odds are that they would require different components anyways. Tapping would also be a nice feature to have but can realistically wait for down the road as well.
Page 2 of 4 1234
  1. G0704
    By kd4gij in forum Benchtop Machines
    Last Post: 07-07-2016, 12:00 AM
  2. DRO for G0704
    By UMR in forum Benchtop Machines
    Last Post: 07-06-2016, 04:04 AM
  3. No Joy with my New G0704
    By DogWood in forum Benchtop Machines
    Last Post: 07-05-2016, 05:49 PM
  4. G0704... Yes Another One ;)
    By ww_kayak in forum Benchtop Machines
    Last Post: 05-27-2013, 03:47 PM
  5. G0704 or a X-3
    By USN in forum Benchtop Machines
    Last Post: 05-30-2011, 08:24 AM
