587,495 active members*
2,950 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > A2100 control - Format error message
Results 1 to 5 of 5
    Jun 2011
    9
    I am getting a message box displayed :
    Format Error
    Error formatting cycle message. ID : 0x280001
    This comes on repeatedly after power-up. It can be cleared (eventually) by repeatedly touching the "OK" box on screen - though after pressing this the normally blue box goes grey rather than clearing.
    This message has started coming up after the problems I described earlier where the main circuit breaker tripped repeatedly due to an X axis servo wiring fault - the control being shut down without having saved data.
    Could anyone suggest how to cure this, please ?
    Regards,
    Nigel Barraclough
    Jun 2011
    9
    I spent a bit more time on the machine yesterday, so a bit more information.
    The messages that appear are not all the same - the last digit of the address varies. I have seen 0x28000A and 0x28000B as well as 0x280001 noted in the original post.
    The 0x280001 message comes up when I press the "Mech align" button. IIRC there used to be an information message came up prompting the carousel to be positioned at station 1 before confirming using the "Mech align" button.
    I can align the axes & the toolchanger and then clear the error messages, so am assuming that I have some corrupted message files somewhere ?
    The control appears to be operating from a 1GB Compact flash card - I can see no HDD. The card shows a directory called "Mustang" - is this the CNC operating system ?
    Can anybody point me in the direction of the message or info files, or suggest how I can repair or reformat the files, please ?
    Regards,
    Nigel B.
    Oct 2008
    123
    hello
    i think the flash card replaced the original hard drive (probably by me). i think you might need a replacement or the software reloading.
    regards
    mallardfizz
    Jun 2011
    9
    Hi Dick,
    Your name is pencilled on the electrical schematic along with a mobile number. Can I contact you on that number ? (ends 594)
    The machine is the Sabre 750 that was in Guernsey.
    Regards,
    Nigel B.
    Oct 2008
    123
    yes you call me on that number.
    regards
    Dick
    (mallardfizz)
  1. Arrow 750 with CT control error message 9036
    By DEAN-O in forum Cincinnati CNC
    Last Post: 02-11-2019, 01:17 AM
  2. DX-32 Control, Error Message, No Clue!
    By minton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-30-2011, 04:34 AM
  3. A2100 Arrow 500 Error help
    By kentsui in forum Cincinnati CNC
    Last Post: 10-31-2010, 06:44 PM
  4. GE control error message
    By Good_GuyMN in forum DNC Problems and Solutions
    Last Post: 02-14-2009, 08:22 AM
  5. A2100/NT boot error
    By kentsui in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-14-2008, 10:44 PM
